There's no such thing as "The correct tyre" as long as size, load and speed indexes match so you will be fine. Though different tyres do sound and feel a bit different I agree. And stay away from RFT, they've got a poor and noisy ride in general due to the stiff sidewalls.June wrote: ↑13 Aug 2019, 19:32Yes my S80 and I don't know if they are run flat. Does that make a difference? I hate that Michelin discontinued the correct tires! With those I know what to expect. 25 to 30K of smooth quiet dependability. The Bridgestone come with a 30 day warranty if dissatisfied they will remove them and put something else on. I really hate that these cars are getting old! June
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
Re: What did you do to your Volvo today? (now Sticky)
- Has thanked: 305 times
- Been thanked: 517 times
I agree, don't get too hung up on having the OEM tire. Of course, it can sometimes be the best option being that it's the tire that Volvo intended to be used on your car, however your S80 is 15 years old... there are many newer model tires that are better, I'm sure!
I believe the OEM tires for the XC90 were a discontinued Pirelli model. I ended up going with Nokian zLine A/S 255/50R19s, and I've been happy with them. Nice and smooth, quiet ride, and great traction in the rain. Plus for that massive size, they were really cheap... I think I paid around $450 at Simple Tire.
That was my reaction! Hahaha
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
I don't believe June pay that much for it but it probably was not the run flats either. Costco provided that and another 20 tires that would work depending on her needs.
I agree, depending on one's driving habit and area in the country many tires will work for the same car. Not sure if this is the case now but years ago some OEM tires were made specifically for new cars with less tread so good for only 20~25K miles.Rattnalle wrote: ↑13 Aug 2019, 23:14
- Has thanked: 1506 times
- Been thanked: 3822 times
Another epic upstate NY road trip.
ALB BNG ITH COR ITH BNG ALB
i88 was perf3ct with 65 mph in the T5 and snug P80 seats
Ended day with visit from my VW friends, but 0500-2200 is getting to be a long day for me
- June
- Has thanked: 523 times
- Been thanked: 261 times
I agree, depending on one's driving habit and area in the country many tires will work for the same car. Not sure if this is the case now but years ago some OEM tires were made specifically for new cars with less tread so good for only 20~25K miles.MoVolvos wrote: ↑14 Aug 2019, 17:24I don't believe June pay that much for it but it probably was not the run flats either. Costco provided that and another 20 tires that would work depending on her needs.
I actually paid more! I was unaware the tire was a run flat tire. Taking advice from you guys on the run flat aspect, I went back the next morning and canceled the order, and reordered a inexpensive set of Uniroyal tires as a stopgap set until Michelin gets the Primacy 4 to market.
The Uniroyal tires were installed yesterday and the European drive feeling is gone. Now it feels like a big Buick on the road. Even the Steering feels different. Like it went from 75% power assist to 100%. No feel to the wheel at all during lower speeds in particular. Time will tell on stopping distance and wet weather driving has been effected. Specifications are the same tire wise, but drive completely different. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- ZionXIX
- Has thanked: 65 times
- Been thanked: 194 times
Replaced the coolant temp sensor today. Temp readings are quicker, low speed fan is finally working! Coolant no longer spilling over!
I'm hoping my mileage may change too. Been running rich for a while.
I was surprised at how tight the thermostat housing bolts were even though I just replaced them last week. I decided not to play around this time. I put a thin smear of antisieze on them. I dont plan on fighting with those in the future.
Wrapped up the PCV in the S60 the other day, then helped install iPd lowering springs and an adjustable panhard bar in my cousin's 240. That car rides way better now! Way less body roll than the stock springs! I can't wait to feel it once he gets the sway bars!
Took the R to its first meet last night and talked to a few other local Volvo enthusiasts. I love being able to drive it now, but it's just incredibly annoying that it won't boost more than 10 PSI. I'm really thinking it may be the turbo at this point, I can't find anything else wrong. My cousin also tells me that the car puffs a good amount of black smoke every time I get on the throttle... which doesn't surprise me, I'm getting 15 MPG at best with the AC running and with the lack of boost, I'm not at all surprised it's running crazy rich.
Anyone got a cheap K24? Haha
- Rattnalle
June: Uniroyals are cheap for a reason..
Michelins are almost always good. I've seen some people on here get Nokians which are also good. Good Years European made tyres are nice and well priced but I'm not sure if they're for the European market only. Eagle F1 for example.
- manovlov
- Year and Model: 1995 850 GLT 2.5 170
- Has thanked: 620 times
- Been thanked: 143 times
I have installed new suspensions front and rear (except springs for the rear), and the big noise I had thinking it was coming from the clutch was done by a front spring on two points: the spring itself and suspension strut support Bearing front axle upper.
I replace parts stamped Volvo on them, and the car is a 1995 model. These seems to be originals parts... By this work, I re discover my car.
The next jobs will be, replace the main silencer, and fix the noise I hear from the rear brakes pads on the left side (LHD).
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
I have to step in here and defend the Pilots. I had Pilot Super Sports on my old Fiesta and they were great tires...for sporting applications. Lots of grip, good wet performance, decent treadwear for soft tires, quiet enough on the highway. Probably not the best-suited to an S80, but good tires in their own right.
