Replacing rear shocks on '06 V70. Should upper shock mounts automatically get replaced. Outside of being torn (mine are not) why would they be replaced. Rubber pliabilty ?
Thanks all. G.G.
'06 V70 upper shock mounts Topic is solved
- GlennG2759
- Year and Model: 2006 V70 NA
- Has thanked: 112 times
- Been thanked: 17 times
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I don't think it's needed for the rear ones. Rarely heard of them going bad (the front ones however do). A few tips if you need www.youtube.com/watch?v=f7gsgr9YWy4
- SuperHerman
- Been thanked: 207 times
I ordered a set a number of years ago. Removed the old ones which looked perfect and returned the new set as unneeded.
If they look fine keep what you have.
- - Pete -
- Has thanked: 80 times
- Been thanked: 175 times
Were your dampers leaking oil?
Or are you doing this to improve the ride in the rear of the car?
I've replaced several rear & front coil springs (they rust & crack over time), but never had a rear damper that was leaking. To me, if it ain't leaking, I don't mess with it.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- Has thanked: 1505 times
- Been thanked: 3818 times
If it’s under an hour job I would re use those parts.
Rocking it in the 518...
