- Pete -
Has thanked: 80 times
Been thanked: 175 times
Post by - Pete - »
Took a full body shower using Zerex G-05 today. Even had a mouthful of it at one point but couldn't find my toothbrush. Amazing how much coolant comes out when you crack open the bottom turbo cooling line. Also amazing how much drinking it takes to remove that flavor from your mouth.
Anyhow, removed a bevel gear & driveshaft (again) for fun, just to make sure I "still had it". Fortunately that exercise wasn't for naught. Turned out the DEM pump had ceased operating so put a new one in for resumed AWD function.
matthew1 wrote: 10 Sep 2019, 16:14
Whoa. My iPD gauge had proper markings. The problem with those is that you couldn't see them :lol: Boost gauge install
I didn't notice any notchy action.
Like you, I struggled with placement. Headliner, A-pillar, instrument cluster... I tried them all.
I believe yours is a previous generation.
Yep, my IPD one is notchy (not horribly), and there aren't any kinks in my nylon line. Looks like they used to use vinyl tubing, wonder if that accounts for the difference in action? The $14 ebay one is smooth as silk & every bit as accurate as the IPD one & has a smoked lens that appears black with the ignition off. Not ripping on IPD, I love lots of their stuff & have spent oodles with them (haven't we all?), simply saying their gauge isn't worth $60 or $70 or whatever it costs.
I still need to wire them so they are dimmable.
Anyone want to wager a bet as to how much longer this collar sleeve/BG input is going to last? 276,500 on it as is. $5 beer money to the winner.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
Went with the Premiers.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1240 times
Post by matthew1 »
- Pete - wrote: 11 Sep 2019, 22:13
It's gotta be the mechanics of the gauge -- your IPD -- that are low quality to make the notchiness. The tube's the tube. Air pressure is air pressure. Could be metal, rock, or plastic, it's all the same.
When you get it to dim by wiring it to the gauge cluster, you'll have that Tingly DIY Feeling™ we all get every so often. $5 beer money says it.
Also -> Amazon link
Antoine240bk
Year and Model: XC70 2.5T-2006 - 4C
Has thanked: 12 times
Been thanked: 30 times
Post by Antoine240bk »
Did a full maintenance to the XC70 8)
Rear rotors & rear brake pads and handbrake pads with new springs.
Front brake pads and a good clean on four brakes.
Oil drain & oil filter, air filter and a carbon cabin filter.
Spark plugs, petrol filter
Bva drain & fill 3.5l (Automatic gearbox) :wink:
Volvo XC70 2.5 T AWD P2 B5254T2 - 12/2005 Four-C Previous : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -LPG - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
TheMrFailz
Year and Model: 2002 V70 2.4T
Has thanked: 7 times
Post by TheMrFailz »
Blew my transmission up a couple of days ago pulling into a parking lot. Good old aisin.
Professional jerry-rigger.
Has thanked: 1498 times
Been thanked: 3810 times
TheMrFailz wrote: 19 Sep 2019, 12:58 Blew my transmission up a couple of days ago pulling into a parking lot. Good old aisin.
Yeah, Volvo transmissions suck. My Toyota ones last forever.
:D :D :D
TheMrFailz
abscate wrote: 19 Sep 2019, 13:56
:D :D :D
Think you've got that one backwards there friend. :D
ionianp2
Year and Model: 2004 Volvo s60
Been thanked: 7 times
Post by ionianp2 »
I replaced the steering rack boot on my S60, as it was brittle and with two holes. Luckily I was able to slide the new boot through the tie rod joint.
Also sprayed some AT 205 on surrounding bushings to rejuvenate them.
Has thanked: 292 times
Been thanked: 765 times
matthew1 wrote: 13 Sep 2019, 08:36 ... When you get it to dim by wiring it to the gauge cluster, you'll have that Tingly DIY Feeling™ we all get every so often. $5 beer money says it.
You can also wire it to the accessories connector, maybe it's the pink wire that dims with the dimmer switch? Don't remember ...
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Last night I moved the S60 R from the front of the house to the back, went to move it again and the key wouldn't turn! As is common, the pot metal pin had broken off.
This morning I Dremeled open the steel plate underneath the lock cylinder, dropped out the broken pin, 40 minutes later the car was back on the road.
Hopefully this fix is enough, I didn't see any other pieces jammed up or floating around in there.
Also, last Saturday on the same car I replaced the fuel pressure sensor. Car would sporadically hesitate just a bit, and the code for FPS was detected by VIDA. There was no CEL. Bought the Bosch unit, installed, problem didn't surface again this week and no code set so far.
'06 S60 R, 197k
