1998 V70 T5; problem hot starting & occasional brief power loss at speed
clifford06
- Year and Model: 2000 T5
- Has thanked: 6 times
- Been thanked: 4 times
Re: 1998 V70 T5; problem hot starting & occasional brief power loss at speed
If injectors spray when hot , What could be my next point of focus ? ECU ?
- Has thanked: 1497 times
- Been thanked: 3809 times
If it fires in ether, and the injectors are delivering fuel, the fuel delivery amount is wrong.
I think you need an oscilloscope to confirm the injector pulse ( more accurately , how long the ECU isnpulling the injectors to ground
An ECU swap is the Mossberg method if you can’t get a scope , but you are getting close, not much else left
Send me your coordinates, TX travel planned soon.
clifford06
Dallas. Been busy with work and family . Could injector relay act just like a fuel pump relay ? Meaning , could it stop working or cause a stall when hot ?
clifford06
Also , while doing research, I saw something about air pump relay having the same " value " as the injector relay . I guess this means they are interchangeable ? If so , I have a few relays from a salvage run that I could try . Thoughts and helping opinions always welcomed !
- misha
- Has thanked: 152 times
- Been thanked: 402 times
They are NOT interchangeable and also visualy not the same.
Yes...main fuel injection relay could make problems when it becomes hot....just like any other relay.
Try to swap it with a used one and see if problems go away.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 292 times
- Been thanked: 765 times
erikv11 wrote: ↑17 Sep 2019, 17:41 There's also the gray fuel injection main relay up under the radiator - or maybe that relay is not used on a 98? My 98 is not here or I would check. Someone else will remember.
It's basically guaranteed to be an electrical/electronic part, that when it heats up the resistance gets too high. V = IR so currrent drops and the component stops working and the car stops working. Could be a relay, sensor, or a critical wire that is thin or poorly connected.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
clifford06
Thanks for the reply .I'll make a salvage run this weekend. You quoted from the same thread I read .
clifford06
Hello ! Today I spoke with local Volvo dealer about price of a injector relay ( local salvage yards are bare of S70s ), and the part number matches main relay in main fuse box. I called back and was emailed a schematic showing the location was in the main fuse box , not under radiator cover . Only thing on radiator cover is cooling fan connections.
From the pic , it seems it goes in slot #2 in fuse box , which is labeled Air Pump on the underside of fuse cover . I have no fuse there , never have . Maybe that was to show general location. I think , maybe my problem is the main relay itself ? I have a matching relay from previous salvage run that I'll put in and see what I get . Any input is welcomed !
clifford06
Swapped main relay after getting car to temp, and still same result . I'll swap cam sensor next .
Yeah, I didn't think the 98 had the relay at the radiator. This is a sticky one hang in there ...
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
