1999 T5V70M56 road incident report, misfiring [ bad #2 coil]
Been thanked: 4068 times
Preamble, mileage on car 239748
I thought I detected rough running for the last two week at startup and cold idle, but after 60 seconds idle was smooth, so I took no action. I did check #3 plug and found it at 0.032 with some tip wear, and meant to compare it to new, plugs have 24k on them, Volvo OEM style. Coils estimated to be 80k miles, OEM Bosch
Leaving downtown ROCHESTER, two hours after a long drive, I had a missing cylinder, low power, and bad exhaust smell. It cleared after 5 minutes of driving to my next destination. I then headed out 490 towards Buffalo, and the miss returned with a CEL.
The incident
I was able to reach my ObD in the glove box and read codes, and had two...P0352 #2 coil primary failure and #2 misfire P0302
The repair
I pulled over, T25 for cover, M6 for coil screw, spare coil from parts kit, installed and miss cleared. I will test today on the drive home.
Waze told me instead of being 15 minutes early to my next destination, I was now only 8 minutes early. I lost one minute saying hello to the guy who pulled over to help in the first 30 seconds. It’s A Buffalo thing.
Analysis
Relatively early coil failure. I will order a replacement but have to think about replacing other four coils. This same repair on the GW would suck.
dalel
Year and Model: 1998 V70
Has thanked: 29 times
Been thanked: 7 times
Post by dalel »
Thank God you keep a spare acorn on the instrument panel.
You have to have nuts to drive these cars
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
I have 5 cheap "don't want to know" brand coils currently running on mine that were made in Japan. I have my orig. 5 as well. Suffice it to say everything checks out at this point. If you ever need one, hit me up.
My daughters were coloring the acorns the other day. Whatever kept them occupied was a good deal =)
Thanks again!
Love those kids.
Yes, it’s the car that loves me by breaking down on the wide shoulder of I490 on a beautiful fall sunny day with minimal traffic and says “ please put in that spare part you are carrying for me”
Drove from BUF to ITH to ALB with no misfires
700 miles later, problem has returned. Misfire reported on cylinder 2 with two codes. P0302 and P0352 ( coil primary failure)
I’m guessing the coil wiring has gone bad, it misfires at idle and low load, and then clears up at cruise rpm of 2000-2500
I did swap in another used coil and it did not help
Well this one turned out to be an epic troubleshooting thread. Stand by for the read of the week.
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
I was born being on standby ...
1996 855 R,
2010 V70 D5,
Recap: I had a symptomatic slight miss at idle, which turned into a constant miss at speed, pulled over on highway, replaced with used coil, all well. Cylinder 2 code misfire popped, and coil 2 replaced.
Once home, I pulled plugs, checked coil bolt tightness, changed plugs for Volvo ones (24k on old)all well
Drove two trips to Boston and one to NJ, total about 900 miles, no problems,
Departing on trip, constant misfire came back at idle and medium load, car runs on 5 at speed with occasional misfire. Flashing CEL light, exhaust smell, and P0302 Po352 codes set.
Bachelors level troubleshooting
Replaced coil with tested spare, did not solve problem. Took car home and took P2
Masters level Troubleshooting
Started car, smooth idle
As car warms, miss in cylinder 2 develops. As I manipulate wires, which are in medium condition, I seem to generate/ stop miss but it is not definitive. I am unconvinced it is a wiring fault in the harness. We swap coils 1 and 2 and problem does not move.
PhD troubleshooting
When you get stuck, you go full bore diagnostic
Step 1: Ignore prior history and get the data
I will put the solution 20 lines down in tiny type for those who don’t like puzzles, for those wishing to test their skills , see poll
STOP HERE IF YOU WANT TO HONE SKILLS and go to poll here.
the key here was ignoring prior history. It turned out one of my brand new Volvo spark plugs from FCP would misfire when hot. The original failure from two weeks ago was coil, and this failure was brand new out of box quality issue with a Volvo part. We were able to confirm by reinstalling plug and duplicating fault. The old plug did notmisfore up to 6000 rpm.
Has thanked: 2203 times
Been thanked: 1852 times
Not a common issue but over many years I have had maybe 3 bad out the box spark plugs. 1 was Volvo OE and others were OEM Bosch.
Strange that it happened in the same cylinder. Wete the plugs fitted at same time as the new coils?
Similarly had a new Volvo branded coil go out on the V70 base I renovated. Coils were bought from an on line supplier but not a Volvo dealership. Maybe some hokey Volvo parts out there or diminished OE quality as I have speculated before.
If plugs were replaced at same time as new coils, maybe one or other was bad and took the other out. As you have said many times. If it worked fine before you worked on it then check the work/parts you changed. Well done finding the issue all the same!
