1996 960 problem please help
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
thevolvoking
Year and Model:
Post by thevolvoking »
ok it only happens everynow and then, what happens is i get in my car start it and then try and shift and it will not let me shift out of park. then i try my windows and they do not work either... i then turn off the car and restart it and it then works. if anyone knows the cause of this problem please let me know.
thanks
DiezelV
Year and Model:
Post by DiezelV »
Failing shiftlock override microswitch inside the shifter console is common on 960. Very cheap part but dealer will charge $$ to replace, If you have the time you can do it yourself.
http://www.brickboard.com/FAQ/700-900/T ... gOutofPark
I'm not shure how the window failing could coincidental though
jww1965
Year and Model:
Post by jww1965 »
I had a 740 that did this and the problem was the Ignition switch (key) was not returning all the way. try turning the key slightly toward the off position.
good luck
southerngal
Post by southerngal »
I had similar problem. The microswitch should have been replaced under manufactor's recall warranty. There was a recall in 1997 for this switch. I had to have this switch replaced twice within two years. Also, you could have a faulty emission sensor, which will do the same thing. I also had this replaced under manufacture recall---it failed too. Car now has 160,000 miles. You should check with the highway commission for all of the recalls for the 1996 960 volvo---there were around 3or 4 recalls. Also, find a good independent volvo repair shop.
