Starrter problems
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
fizzilee
Year and Model: 2004 V50
Starrter problems
Post by fizzilee »
Hello, my Volvo V50 from 2004, an 2.0D with about 270tkm. The engine does not start. If I turn the ignition switch to position III nothing more happens than at position II, the stater does not turn there is no click. So i take a look on the starter relais, ther comes no signal from ther ingition switch. If i took a short cable and link Batter+ to the small pin at the starter (magnetic switcht), the engine starts.
HELP :-)
Now i removed the speedo to take a look on the ingition switch, but i have nor wiring diagramm. Which of the two connetros at the ignition is for the starter? Which cable color to the starter Relais?
Please help me with a wiring diagram or another ideas.
Greeting from bad english speaking austria :-)
