Has thanked: 1505 times
Been thanked: 3817 times
oragex wrote: 11 Oct 2019, 17:08 Uploaded a video showing a few ways to open a stuck hood that won't open www.youtube.com/watch?v=HwOv6AIqxHY
Bookmarking this one to make it a sticky/ reference document for stuck hoods
tyguyc
Year and Model: 2004 xc70
Post by tyguyc »
I did the hand sanitizer trick for the radio knobs, using company hand sanitizer. Shhh.
TheMrFailz
Year and Model: 2002 V70 2.4T
Has thanked: 7 times
Post by TheMrFailz »
Delete all autotragic fragboxes.
Professional jerry-rigger.
GlennG2759
Year and Model: 2006 V70 NA
Has thanked: 112 times
Been thanked: 17 times
Post by GlennG2759 »
Nice engine hoist !!
tyguyc
Post by tyguyc »
I investigated the RH turn my TSC Light flashes under power.
Took off the tire and took off the ABS Sensor and rotated the wheel to find my
ABS Tone ring had snapped. So the part has been ordered and waiting for it
so that I can install it.
StickyPocket
Year and Model: 2004 S60 2.5T AWD
Has thanked: 42 times
Been thanked: 6 times
Post by StickyPocket »
Changed front right wheel bearing and hub assembly. Smooth again.
2004 S60 2.5T AWD
TheMrFailz
Now i've gotta go find t50 torx bits so I can take the torque converter off.
Edit: Also, the peg that aligns the starter with the transmission casing was so stuck in there that while I was rubber malleting it out I actually cracked the bit of the trans casing that holds it.
tyguyc
Post by tyguyc »
TheMrFailz wrote: 19 Oct 2019, 16:22
Mr. Failz, Does this mean that you are going to swap a m66 box?
TheMrFailz
tyguyc wrote: 23 Oct 2019, 08:00
Yes. :twisted:
Seriously though screw the autos on these things. Nothing but pain while it was pre-gravel filled.
GlennG2759
Replaced spring seats (Rein), mounts (Lemforder), & all strut hardware on '06 V70 103k. No more clunks & rattles. Struts were fine, thanks Pete & Abscate for advice.
