Did you know? 🤔
Strut question ?
2001 - 2007 XC-70
GlennG2759
Year and Model: 2006 V70 NA
Has thanked: 69 times
Been thanked: 11 times
United States of America
GlennG2759
Strut question ?
Post by GlennG2759 » Sun Oct 20, 2019 2:07 pm
I just got done breaking down my struts on '06 V70. One spring seat (metal collar) totally detached, the other one torn on the underside about 180 deg. Ordered new seats, mounts, and hardware. I tested the struts by pushing rod all the way down. One returns to full extension within a few seconds, the other one takes quite along time and several times only to about 3/4 full extension. There is no sign of leakage. Does that mean there done and being this far into should I go with new struts. Opinions and strut recommendations would be greatly appreciated. Thanks, Glenn
Has thanked: 318 times
Been thanked: 986 times
Trinidad & Tobago
Re: Strut question ?
Post by abscate » Sun Oct 20, 2019 6:11 pm
They are dampers, not springs. If you had a good ride and no under damping, keep the P2 struts; they run 200k if run carefully
These users thanked the author abscate for the post:
GlennG2759
Link To Volvo Glossary
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 29 times
Been thanked: 70 times
MoVolvos
Post by MoVolvos » Sun Oct 20, 2019 9:08 pm
The internal valving do go bad. External leakage is just the most obvious indicator of a worn / bad strut. They are both bad actually. They should neither fully extend in a few seconds nor extend to only 3/4 of the full height.
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
MoVolvos
MoVolvos
Post by MoVolvos » Sun Oct 20, 2019 9:23 pm
Have installed these brands on various cars. After releasing the band or wire that keeps them compressed during shipping both units should rebound the same. Actually got a set of KYB GR-2's one time and one was defective out of the box. Just rebounded within a few seconds.
KONI, Bilstein, KYB, Monroe, Gabriel, ECCPP.
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
- Pete -
Has thanked: 55 times
Been thanked: 81 times
- Pete -
Post by - Pete - » Sun Oct 20, 2019 11:56 pm
You're around 100k I believe. Like Steve said, I'd leave them be. Only time I'd think of replacing is if I had wheel hop or oil/debris caking. Our 04 XC still rides on it's original's, dry as a nun's bush & smooth/quiet as can be. I've replaced seats several times & a couple coil springs on it over the years, but the "shocks" just keep going.
Not discounting BKM in anyway, by the way. Just my experience over a few hundred thousand miles.
These users thanked the author - Pete - for the post:
GlennG2759
2001 V70XC 146k
2004 V70 AWD 141k
2004 V70R M66 144k
2004 XC70 287k
2006 XC70 155k Sold
MoVolvos
MoVolvos
Post by MoVolvos » Mon Oct 21, 2019 1:24 am
I have no experience with XC's. Are those SACH or Volvos? Both of mine are in need of Struts with less than 135k on either. 2003 S80 has KYB's, this before I purchased it. 2008 C30 takes bumps pretty hard and front seems low. Had new KYB's installed on a 95 Plymouth Grand Voyager 3.0 years ago. Just Meh, Monroes would have been better.
Rear shocks on both Volvos were shot when purchased. Each one had one blown so no rebound. Currently have Bilsteins on C30 (Firm) and ECCPP (Compliant) on S80.
These users thanked the author MoVolvos for the post:
GlennG2759
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
- Pete -
- Pete -
Post by - Pete - » Mon Oct 21, 2019 8:07 am
Our 04 XC front is Sachs.
That's a good point, taking hits/bumps pretty hard - I'd say that the XC's are definitely not as abusive on shocks as say the V70's, due to cushier damping. Rears are pretty obvious if they are not providing damping anymore. Wheels tend to hop after hitting bumps. Our V70R does this (cringe then cry at price). Pretty obvious when following in another vehicle.
Still, on the fronts, if they aren't oil laden & caked with debris, check for damping by pushing down on the piston rod as hard and fast as you can (don't impale yourself). Do the same for extension - Pulling up hard and fast on the top hat. If it's still damping & not just "free" feeling I'd just reuse them. Some of ours extend when I've had the coils off, some don't. But they all are doing their job of damping.
GlennG2759
2001 V70XC 146k
2004 V70 AWD 141k
2004 V70R M66 144k
2004 XC70 287k
2006 XC70 155k Sold
GlennG2759
GlennG2759
Post by GlennG2759 » Mon Oct 21, 2019 8:34 am
Yes, they still seem to be dampening in both directions I guess I was wrongly expecting them to react like a shock. This is first rebuild of strut for me and decided to reinstall original, FCP has a Mayle strut on sale for 50 bucks, but I decided against them. Does anybody have any experience or info on these.
Thanks
Trinidad & Tobago
Post by abscate » Mon Oct 21, 2019 8:21 pm
I have been inspecting the shrubbery at the local convent and confess the thing in common with the suspension is it is Sachs-less.
- Pete -
Has thanked: 0
Been thanked: 131 times
Post by cn90 » Mon Oct 21, 2019 9:24 pm
In June 2019, I installed the Sachs Struts Assembly, sold by FCPEuro.
PN is: Sachs SAC-033078, $250/each side.
Well worth the money.
So far so good.
https://www.fcpeuro.com/products/volvo- ... 78#fitment
