RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
bmdubya1198 wrote: 20 Oct 2019, 08:56 It's an egg crate? Hmm... I'll have to make sure the '90 grille works on the non-fog light 940s. I think '90 was supposed to be a special year with minor differences from newer and older cars.
The '90 740 egg crate grille is gray, Volvo part number 1369619.
What I have is the '90 740 black waterfall grill. Marked Volvo part number 1369618 which does not show up in the parts database. Vida list 1369616 Black grille with chromed frame. Typo or 1369616 is with fog light and 1369618 is without?
I pulled it off a 1990 740 without fog lights. We test fitted it on a 940 without fog lights and it fit, I don't recall what year the 940 was.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Ah, I see now. Yeah, I think I'm going to have to get creative and make my own egg crate with the current grille. The '90 740 is the only non-fog light car to come with the egg crate, and the '90 grille won't fit newer cars because of the slightly different hood and headlight trim pieces.
RickHaleParker
bmdubya1198 wrote: 20 Oct 2019, 16:51 The '90 740 is the only non-fog light car to come with the egg crate, and the '90 grille won't fit newer cars because of the slightly different hood and headlight trim pieces.
The information I found is a mixed bag. Some sources indicate it will fit 90 - 92 740/940.
If I could recall what year that 940 is, it would be a big help.
bmdubya1198
RickHaleParker wrote: 20 Oct 2019, 17:44 The information I found is a mixed bag. Some sources indicate it will fit 90 - 92 740/940.
Mine's a '93.
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
What Can Go Wrong?
1996 Volvo 850 glt wagon - $1000
https://raleigh.craigslist.org/cto/d/du ... 18594.html
All done/replaced within the last 2 years and 8000 miles:
Engine/driveline:
timing belt
timing belt tensioner
water pump
spark plugs
spark plug wires
distributor cap
distributor rotor button
battery
pcv system
coolant temperature sensor
2 engine mounts
both CV axles
abs/traction control module
fuel filter
regular fluid and filter changes
Heating/Cooling:
a/c overhaul and repair
heater core replacement
Suspension/steering:
both front struts
both front upper strut mounts
both front lower control arms and bushings
both front bumpstops
both front strut billows
tie rod ends
power steering rack billows
Interior:
carpet floor mats
headliner
power moonroof
weathertech cargo liner
misc. trim pieces and clips
Misc.:
Hella Sharptones horns
Asking 1000 or best offer
bmdubya1198
Not too bad for the price. It looks like a pretty clean car overall.
MoVolvos
Post by MoVolvos »
bmdubya1198 wrote: 20 Oct 2019, 21:52 Not too bad for the price. It looks like a pretty clean car overall.
Thanks, curtain air bags on 99 S70 and above, is that correct?
Has thanked: 1500 times
Been thanked: 3812 times
MoVolvos wrote: 20 Oct 2019, 22:32
I thought every P80 had curtain air bags?
MoVolvos
Post by MoVolvos »
My 98 S70 T5 did not have them, just the SIP.
MoVolvos
Post by MoVolvos »
MoVolvos wrote: 20 Oct 2019, 23:58 My 98 S70 T5 did not have them, just the SIP.
Looks like the SIP goes to the head. Couldn't tell on the red one.
