Ignition switch Topic is solved
Guest
Ignition switch
Post by Guest »
After making a sharp turn into a parking space the ignition switch cannot be turned into the fully locked position. The problem has happened twice in the past two weeks. I restart the car move it a short distance, repark and the switch is back to normal and can be locked.
What do you think is the problem?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1248 times
Post by matthew1 »
It's the steering wheel. Jiggle it because it's interfering with the ignition turning mechanism. Same thing happens to prevent you from starting the car... same solution.
Also -> Amazon link
