After making a sharp turn into a parking space the ignition switch cannot be turned into the fully locked position. The problem has happened twice in the past two weeks. I restart the car move it a short distance, repark and the switch is back to normal and can be locked.
What do you think is the problem?
Ignition switch Topic is solved
- Has thanked: 2660 times
- Been thanked: 1249 times
It's the steering wheel. Jiggle it because it's interfering with the ignition turning mechanism. Same thing happens to prevent you from starting the car... same solution.
