Get loud click sometimes when hit pothole sounds like something hits windscreen. Can anyone advise or suggest.
Regards
BobbyS1
Loud click
- BlackBart
- Has thanked: 927 times
- Been thanked: 884 times
Front sway bar end link? I had a loose fastener there and it made a loud click / pop at every bump.
- Has thanked: 1498 times
- Been thanked: 3810 times
Probably plasticcracking in the dash from broken mounts. Somewhat endemic to the P80 cars
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 111 times
+1 on broken dash mounts.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- E Showell
Drop link in UK, I think.
'95 855 auto (sold)
'95 855 auto (sold)
- RickHaleParker
- Been thanked: 958 times
Front damper mounts. Open bonnet, grab wing at the well, bounce up and down keeping your eyes on the damper mount. Check both sides.
- RickHaleParker
A Strut is a damper. You only have two on the car, they are on the front.
Front Damper mount = Strut Mount. The rubber/metal part that binds the top of the Strut to the body. When the rubber rips loose. The top of the Strut is floating and will produce a clunking noise expectedly, when you hit a pot hole. You can see the rip when you bounce the car up and down.
Damper can be a Shock or a Strut but, the terms Shock and Strut are not interchangeable. A Strut is a structural part of the suspension system, a shock is not.
