Loud click
BobbyS1
Year and Model: 2000 V70 Estate
Loud click
Post by BobbyS1 »
Get loud click sometimes when hit pothole sounds like something hits windscreen. Can anyone advise or suggest.
Regards
BobbyS1
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Front sway bar end link? I had a loose fastener there and it made a loud click / pop at every bump.
Has thanked: 1503 times
Been thanked: 3817 times
Probably plasticcracking in the dash from broken mounts. Somewhat endemic to the P80 cars
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
+1 on broken dash mounts.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
BobbyS1
Post by BobbyS1 »
To Black Bart
Is this the anti roll bar?
I Live in England different names of parts. Many thanks.
BobbyS1
E Showell
Post by E Showell »
Drop link in UK, I think.
'95 855 auto (sold)
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Front damper mounts. Open bonnet, grab wing at the well, bounce up and down keeping your eyes on the damper mount. Check both sides.
BlackBart
Post by BlackBart »
BobbyS1 wrote: 14 Nov 2019, 09:10 To Black Bart
BobbyS1
Yes.
BobbyS1
Post by BobbyS1 »
Hi guys,
Are damper mounts the struts shocks not sure Will the Haynes manual clearify?
Regards
Bobby S
RickHaleParker
BobbyS1 wrote: 18 Nov 2019, 11:06 Are damper mounts the struts shocks not sure Will the Haynes manual clearify?
A Strut is a damper. You only have two on the car, they are on the front.
Front Damper mount = Strut Mount. The rubber/metal part that binds the top of the Strut to the body. When the rubber rips loose. The top of the Strut is floating and will produce a clunking noise expectedly, when you hit a pot hole. You can see the rip when you bounce the car up and down.
Damper can be a Shock or a Strut but, the terms Shock and Strut are not interchangeable. A Strut is a structural part of the suspension system, a shock is not.
