2004 V70R, AT, $4250 OBO Helena, Montana
05Meanstreak
Year and Model: 04 V70R
Post by 05Meanstreak »
For sale 2004 V70R with 216K miles. I have a list of all repairs and upgrades since I've purchased the vehicle on 6/8/2016. Mileage on purchase date 195702. I also have a CarFax and a clear Montana title on hand. Attached is the repair list and CarFax link. The vehicle comes with winter tires on the original rims, a set of new tires on Kon Oversteer 17" wheels, OEM roof racks, car cover, front winter floor mats, an oil change kit, a spare rebuildable K24 turbo, and other misc. parts.
2004 Volvo V70R
VIN: YV1SJ52Y742395739
file:///Users/kurtisrobinson/2004%20V70R/CARFAX%20History-Based%20Value.html
Purchase/Title Date: 6/8/2016
Mileage on dare of purchase : 195702
Mileage as of 11/06/19: 216373
Parts/Maintenance in Chronological Order
2016
06/16 Upper engine mount & lower torque transmission mount, left and right wiper arm covers purchase & install
07/16 IPD poly bushing subframe insert kit, front left and right all weather plastic floor mats, left & right windshield nozzles purchase & install
07/16 Recharge AC System
07/16 Replace AT dipstick and seal purchase & install
08/16 Strut brace mount conversion kit & cabin air filter purchase & install
08/16 OEM Volvo roof rack
09/18 Lower right engine mount purchase
12/16 Mud/snow winter tires installed on OEM factory rims at 199,119 miles
2017
01/17 Drain and refill bevel gear, rear differential & doc coupling
02/17 Oil trap kit purchased & installed
02/17 Oil filter housing spare
03/17 IPD Phenolic throttle body spacer kit purchase & install
03/17 Kon Oversteer 17” Wheels purchase and install
04/17 Front brake pads & rotors, left outer tie rod, purchase & install
06/17 Left & right flog light grills & PIAA light kit purchase & install
08/17 XeMODeX Electronic Throttle Body Throttle Body purchase and install
08/17 IPD B4 Servo update kit purchase & install on AT
08/17 VIDA TCM, ETM & ECM software reloads at 205778
09/17 OEM Angle gear sleeve service kit purchase
10/17 Angle gear sleeve service kit install
11/17 Rear brake pads & rotors purchase & install
2018
03/18 Blower motor heater fan & blower motor resistor purchase and install
04/18 Tie rod end and rear wiper motor purchase
03/18 Timing belt/water pump kit install at 197220
04/18 Turbo control valve HD & K24 Billet compressor wheel 6+6 purchase
04/18 Inner tie rod end & rack & pinion boot purchase & install
04/18 Tie rod ends & rear wiper motor purchase & install
04/18 Engine splash shield & drivers & passengers side headlight lens purchase & install
04/18 Turbosmart Compact Shorty CBV & K24 Turbo rebuild kit purchase
05/18 Mototec turbo down pipe with Cat and mottoes touring cat-back exhaust kit purchase
05/18 4 Wheel alignment at 210045
05/18 Rear wiper motor purchase
05/18 Install complete exhaust system
05/18 Rear wiper arm purchase & install
05/18 IPD HD TCC turbo control valve kit & HD upper strut mount and spring seat kit purchase
05/18 IPD upper strut bump stop purchase
06/18 KKK K24 complete standard rebuild by G-Pop Shop
06/18 Waste gate actuator upgrade purchase
06/18 Turbo drain pipe seal kit, CRP seal ring fuel filter, exhaust flange gasket & coolant hose kit for turbo purchase
2018 Continued
06/18 IPD R boost gauge kit purchase and install
06/18 Strut & bomb stop kit install at 211213
08/18 Turbo charger removal and replace at 211213
08/18 AT flush at 211225
09/18 Direct coil & spark plug kit purchase & install at 211225
09/18 Front and rear oxygen sensor purchase
09/18 Turbo charger tune to proper boost
09/18 IPD transmission torque mount purchase & install
10/18 Fuel pump purchase & install at 212795
10/18 Oxygen sensors install
10/18 Fuel pressure sensor purchase & install
11/18 Fuel pressure sensor & fuel pump control module purchase & install
12/18 Fuel pump & filter install - replaced on warranty
2019
02/19 Fuel Pump and gasket purchase
02/19 Replaced fuel pump for the 3rd time with OEM pump due to debris in fuel tank. Fuel tank cleaned and replaced fuel filter at same time at 213677.
07/19 Engine mounts purchase
07/19 Engine mount install & coolant hose replacement with intake manifold gasket install
07/19 New 40,000 mile tire purchase and install at 215876
Total amount of parts, service and maintenance cost from list above $15,877.34
2004 Volvo V70R
2016
2017
2018
2018 Continued
2019
Reason: Subject updated to reflect it's back on the market
05Meanstreak
Reduced Price!
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
Wow, what a nice car, and you clearly took great care of it.
GLWS
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
05Meanstreak
Thanks. This is my first V70R and it is a blast to drive. Previous Volvo's include a 125 Amazon wagon, 122, P1800, 5) 245's and 1 V70XC. This is a great vehicle for the price.
Has thanked: 1503 times
Been thanked: 3817 times
Fred Rogers thanks you for loving your car into being.
I thought 5k was pricy at first but if I wanted an R i would write your number in a heartbeat with that service record
850 LPT
Post by 850 LPT »
I really like the dark contrasting trim on these 04' R's. It's my favorite year.
Why has this not sold yet, I wonder.
05Meanstreak
Thanks for the compliments. Yes it is a good example of a high mileage R that has been taken care of and brought back to the performance level this car deserves. Please take note that the PRICE HAS BEEN REDUCED TO $4250.00 FIRM. Trades considered for a 245 of equal value and condition.
To all you guys who beat on your R and now are trying to sell it as the RaRe caR...
This is why you get $500 and this one will get $5000
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1245 times
Post by matthew1 »
I changed the price in the title to $4250. Beauty R!
Also -> Amazon link
Fly up, do 10 runs down Big Sky , drive it home
:lol:
