For sale 2004 V70R with 216K miles. I have a list of all repairs and upgrades since I've purchased the vehicle on 6/8/2016. Mileage on purchase date 195702. I also have a CarFax and a clear Montana title on hand. Attached is the repair list and CarFax link. The vehicle comes with winter tires on the original rims, a set of new tires on Kon Oversteer 17" wheels, OEM roof racks, car cover, front winter floor mats, an oil change kit, a spare rebuildable K24 turbo, and other misc. parts.
2004 Volvo V70R
VIN: YV1SJ52Y742395739
file:///Users/kurtisrobinson/2004%20V70R/CARFAX%20History-Based%20Value.html
Purchase/Title Date: 6/8/2016
Mileage on dare of purchase : 195702
Mileage as of 11/06/19: 216373
Parts/Maintenance in Chronological Order
2016
06/16 Upper engine mount & lower torque transmission mount, left and right wiper arm covers purchase & install
07/16 IPD poly bushing subframe insert kit, front left and right all weather plastic floor mats, left & right windshield nozzles purchase & install
07/16 Recharge AC System
07/16 Replace AT dipstick and seal purchase & install
08/16 Strut brace mount conversion kit & cabin air filter purchase & install
08/16 OEM Volvo roof rack
09/18 Lower right engine mount purchase
12/16 Mud/snow winter tires installed on OEM factory rims at 199,119 miles
2017
01/17 Drain and refill bevel gear, rear differential & doc coupling
02/17 Oil trap kit purchased & installed
02/17 Oil filter housing spare
03/17 IPD Phenolic throttle body spacer kit purchase & install
03/17 Kon Oversteer 17” Wheels purchase and install
04/17 Front brake pads & rotors, left outer tie rod, purchase & install
06/17 Left & right flog light grills & PIAA light kit purchase & install
08/17 XeMODeX Electronic Throttle Body Throttle Body purchase and install
08/17 IPD B4 Servo update kit purchase & install on AT
08/17 VIDA TCM, ETM & ECM software reloads at 205778
09/17 OEM Angle gear sleeve service kit purchase
10/17 Angle gear sleeve service kit install
11/17 Rear brake pads & rotors purchase & install
2018
03/18 Blower motor heater fan & blower motor resistor purchase and install
04/18 Tie rod end and rear wiper motor purchase
03/18 Timing belt/water pump kit install at 197220
04/18 Turbo control valve HD & K24 Billet compressor wheel 6+6 purchase
04/18 Inner tie rod end & rack & pinion boot purchase & install
04/18 Tie rod ends & rear wiper motor purchase & install
04/18 Engine splash shield & drivers & passengers side headlight lens purchase & install
04/18 Turbosmart Compact Shorty CBV & K24 Turbo rebuild kit purchase
05/18 Mototec turbo down pipe with Cat and mottoes touring cat-back exhaust kit purchase
05/18 4 Wheel alignment at 210045
05/18 Rear wiper motor purchase
05/18 Install complete exhaust system
05/18 Rear wiper arm purchase & install
05/18 IPD HD TCC turbo control valve kit & HD upper strut mount and spring seat kit purchase
05/18 IPD upper strut bump stop purchase
06/18 KKK K24 complete standard rebuild by G-Pop Shop
06/18 Waste gate actuator upgrade purchase
06/18 Turbo drain pipe seal kit, CRP seal ring fuel filter, exhaust flange gasket & coolant hose kit for turbo purchase
2018 Continued
06/18 IPD R boost gauge kit purchase and install
06/18 Strut & bomb stop kit install at 211213
08/18 Turbo charger removal and replace at 211213
08/18 AT flush at 211225
09/18 Direct coil & spark plug kit purchase & install at 211225
09/18 Front and rear oxygen sensor purchase
09/18 Turbo charger tune to proper boost
09/18 IPD transmission torque mount purchase & install
10/18 Fuel pump purchase & install at 212795
10/18 Oxygen sensors install
10/18 Fuel pressure sensor purchase & install
11/18 Fuel pressure sensor & fuel pump control module purchase & install
12/18 Fuel pump & filter install - replaced on warranty
2019
02/19 Fuel Pump and gasket purchase
02/19 Replaced fuel pump for the 3rd time with OEM pump due to debris in fuel tank. Fuel tank cleaned and replaced fuel filter at same time at 213677.
07/19 Engine mounts purchase
07/19 Engine mount install & coolant hose replacement with intake manifold gasket install
07/19 New 40,000 mile tire purchase and install at 215876
Total amount of parts, service and maintenance cost from list above $15,877.34
2004 Volvo V70R
2016
2017
2018
2018 Continued
2019
2004 V70R, AT, $4250 OBO Helena, Montana
05Meanstreak
- Year and Model: 04 V70R
- Has thanked: 1 time
Reason: Subject updated to reflect it's back on the market
05Meanstreak
Reduced Price!
- 850 LPT
- Year and Model: 96' 850
- Has thanked: 331 times
- Been thanked: 242 times
Wow, what a nice car, and you clearly took great care of it.
GLWS
GLWS
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
05Meanstreak
Thanks. This is my first V70R and it is a blast to drive. Previous Volvo's include a 125 Amazon wagon, 122, P1800, 5) 245's and 1 V70XC. This is a great vehicle for the price.
- Has thanked: 1505 times
- Been thanked: 3818 times
Fred Rogers thanks you for loving your car into being.
I thought 5k was pricy at first but if I wanted an R i would write your number in a heartbeat with that service record
- 850 LPT
I really like the dark contrasting trim on these 04' R's. It's my favorite year.
Why has this not sold yet, I wonder.
13' Honda Odyssey
13' Honda Odyssey
05Meanstreak
Thanks for the compliments. Yes it is a good example of a high mileage R that has been taken care of and brought back to the performance level this car deserves. Please take note that the PRICE HAS BEEN REDUCED TO $4250.00 FIRM. Trades considered for a 245 of equal value and condition.
To all you guys who beat on your R and now are trying to sell it as the RaRe caR...
This is why you get $500 and this one will get $5000
- Has thanked: 2655 times
- Been thanked: 1248 times
I changed the price in the title to $4250. Beauty R!
Fly up, do 10 runs down Big Sky , drive it home
