Trouble starting 850, need suggestions Topic is solved
Fuel rail check valve?
Post by 96850 »
Is the fuel rail run along the valve cover? I cannot locate the valve you refer to.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1248 times
Post by matthew1 »
It's just in front (as you stand looking at the engine) of the oil filler cap, hidden under an aluminum piece that pops out.
It's the shiny metal bit between the filler cap and the intake manifold in this picture:
https://www.matthewsvolvosite.com/images ... ne_bay.jpg
Also -> Amazon link
potroast
Year and Model:
Post by potroast »
yes, the fuel rail is the shiny rail in between the intake manifold and the valve cover. The schrader valve is underneath a screw-on cap at the end of the rail, nearest to the air cleaner.
