2001V70T5: need some suggestions for AC
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
carboncow
Year and Model: 2003 XC70 2018 S60
Post by carboncow »
our 3rd car doesn't get driven much (once a week maybe) but we need to start driving it more and the AC is funky. It's been itermittant. It seems to start fine but the more stop and go driving around town it starts to not engage.
I threw my gauges on the high/low ports can came up with 35-40lbs (low) and 200-210lbs (high) with AC on high. This seems pretty acceptable to me. I then shut AC system off (off switch) turn it back on and get nothing. Let car sit for 10 minutes and run to store, AC is great...come out of store no AC.
What is most likely to fail on a OLD car at this point...are we talking high/low pressure switches or the HVAC control (which I would assume when set on 100% cool it doesn't matter if the controls are acting up it should be ON) or are we talking issues with the electromagnetic clutch not engaging when it gets it's signal todo so...and since it seems intermittent how would one really check this.
As you can see I know enough about AC work to be dangerous but I'm looking for experience and trends with Volvos of they make/model/year and what to expect first...and how to test.
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
1999 Porsche Boxster
2004 Chevy Suburban LT 5.3L
2013 & 2015 S60 T5
2008 Vw Touareg T2 V6
1989 Sea Ray 340 Sundander
2007 Sea Doo Challenger 180 SE
Has thanked: 1497 times
Been thanked: 3810 times
Classic 'bread clip fix' which is searchable on this site.
AC works for a bit, then stops. When it works, blows nice and cold.
Whats happening is the clutch is getting hot and quitting...if you look at the clutch when it stops working you will see the clutch not spinning.
the fix is.... the 'bread clip"
carboncow
Post by carboncow »
Damn...how did I miss this doctor obvious one! It's all over the freak'n net! Thx.
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
Because the freakin net is full of bad recipes and Volvo porn...so sites like this which separate the wheat from the chaff are valuable.
