BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Real winter!
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Not really. Just above freezing and drizzle so the snow was saturated with water.
Today I took the battery of the charge it's been on the last two days. It's been ages so I thought it was time for a top-up.
xtwister
Year and Model: 2001 Volvo V70 T5
Been thanked: 3 times
Post by xtwister »
Replaced all motor mounts and torque mounts. The rear mount was a real pita.
Now i get a very slight vibration in gear at a stop. Thinking of replacing the strut bar to make it perfect since
that is the only part left.
Also ordered lift gate struts since the current ones are real weak and worried about it coming down and
shattering the rear window.
shiloh51933
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
I replaced the factory purge valve along with some of the EVAP line by the IM. This is the second time I'm replacing the purge valve on this vehicle, 2004 XC70. Fortunately I purchased the first one from FCPEURO.COM, so replacements are covered for life.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
Has thanked: 1498 times
Been thanked: 3810 times
Happy Thanksgiving Shiloh, and its An early Holiday Gift to get a free Blue Box part
GlennG2759
Year and Model: 2006 V70 NA
Has thanked: 112 times
Post by GlennG2759 »
Coolant flush on '06 V70 only to find out I was sent the wrong upper hose. I was going to replace thermostat housing, but I stripped T40's. Left t-stat
housing to head piece in place and transferred the t-start,gasket.temp sensor, and outer housing from new one. Worked out fine, killer heat. What a day!!!!
tyguyc
Year and Model: 2004 xc70
Post by tyguyc »
I took apart the rear Wiper assembly to find a bunch of water and real nasty grease.
Took a little while to get the big plastic gear out but I did, and cleaned up the metal disk behind it with a metal brush.
Reloaded with new grease and tested.
Now it seems to consistently stop (home position) on the left side of the window (which I suppose is not normal, can someone confirm)?
Rattnalle
Post by Rattnalle »
tyguyc wrote: 26 Nov 2019, 08:05 I took apart the rear Wiper assembly to find a bunch of water and real nasty grease.
I don't remember the specifics but you can switch it over depending on how you reassemble it. Mine uses to park on the left but after I renovated it it parks on the right. I just adjusted the wiper arm position to fit.
tyguyc
Post by tyguyc »
[/quote]
[/quote]
I Tried. And looked like a fool to do that. I tested it on the right side, and instead of arcing up it went down and wiped my license plate.
And wierd thing is it used to park on the right side (if I shut off the switch at the right time).
There was a metal plate behind the plastic gear that drove the wiper linkage inside the enclosure.
Is it a vida option to change?
Rattnalle
Post by Rattnalle »
tyguyc wrote: 26 Nov 2019, 13:00
[/quote]
[/quote]
You have to take the arm off then let it run to it's parked location, check with a zip tie that it moves how you think it does then place the arm in the right place with the wiper motor in it's parked location. Done this way there's no risk or putting the wiper in the wrong place and the side it stops on doesn't really make a practical difference.
It's purely mechanical. All the car does is send a current to the wiper motor to start it. That starts it with one wipe then it's back to it's resting position unless it's still got current in which case it'll go again.
