- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
Not really. Just above freezing and drizzle so the snow was saturated with water.
Today I took the battery of the charge it's been on the last two days. It's been ages so I thought it was time for a top-up.
xtwister
- Year and Model: 2001 Volvo V70 T5
- Been thanked: 3 times
Replaced all motor mounts and torque mounts. The rear mount was a real pita.
Now i get a very slight vibration in gear at a stop. Thinking of replacing the strut bar to make it perfect since
that is the only part left.
Also ordered lift gate struts since the current ones are real weak and worried about it coming down and
shattering the rear window.
- shiloh51933
- Year and Model: 04 XC70/'98 V70XC
- Has thanked: 28 times
- Been thanked: 17 times
I replaced the factory purge valve along with some of the EVAP line by the IM. This is the second time I'm replacing the purge valve on this vehicle, 2004 XC70. Fortunately I purchased the first one from FCPEURO.COM, so replacements are covered for life.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- Has thanked: 1502 times
- Been thanked: 3817 times
Happy Thanksgiving Shiloh, and its An early Holiday Gift to get a free Blue Box part
- GlennG2759
- Year and Model: 2006 V70 NA
- Has thanked: 112 times
Coolant flush on '06 V70 only to find out I was sent the wrong upper hose. I was going to replace thermostat housing, but I stripped T40's. Left t-stat
housing to head piece in place and transferred the t-start,gasket.temp sensor, and outer housing from new one. Worked out fine, killer heat. What a day!!!!
- tyguyc
- Year and Model: 2004 xc70
I took apart the rear Wiper assembly to find a bunch of water and real nasty grease.
Took a little while to get the big plastic gear out but I did, and cleaned up the metal disk behind it with a metal brush.
Reloaded with new grease and tested.
Now it seems to consistently stop (home position) on the left side of the window (which I suppose is not normal, can someone confirm)?
- Rattnalle
I don't remember the specifics but you can switch it over depending on how you reassemble it. Mine uses to park on the left but after I renovated it it parks on the right. I just adjusted the wiper arm position to fit.tyguyc wrote: ↑26 Nov 2019, 08:05 I took apart the rear Wiper assembly to find a bunch of water and real nasty grease.
- tyguyc
[/quote]
[/quote]
I Tried. And looked like a fool to do that. I tested it on the right side, and instead of arcing up it went down and wiped my license plate.
And wierd thing is it used to park on the right side (if I shut off the switch at the right time).
There was a metal plate behind the plastic gear that drove the wiper linkage inside the enclosure.
Is it a vida option to change?
[/quote]
- Rattnalle
[/quote]
[/quote]
You have to take the arm off then let it run to it's parked location, check with a zip tie that it moves how you think it does then place the arm in the right place with the wiper motor in it's parked location. Done this way there's no risk or putting the wiper in the wrong place and the side it stops on doesn't really make a practical difference.
It's purely mechanical. All the car does is send a current to the wiper motor to start it. That starts it with one wipe then it's back to it's resting position unless it's still got current in which case it'll go again.
