Apologize in advance for not having precise VIDA fault language. It was something along the lines of sensor voltage too high and cruise control not responding. Accelerator pedal sensor?
ETM is a rebuilt Xemodex unit.
Any thoughts? Feels like car might be running a little rough.
'99 V70 Base ETS lit
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Year and Model: Lots
- Been thanked: 128 times
Sometimes faulty ETMs call out the accelerator pedal which is a potentiometer in this case. Even though it's a XeModex it's entirely possible it has failed. Did you purchase it directly for this vehicle?
- E Showell
Thanks Mike. Yep. Purchased directly for this vehicle. Rough running is really a squeaky dash. Car seems to be performing fine. I need to kill the light before I take for vehicle inspection tomorrow. Even then, they'll probably be able to detect the light was recently extinguished. Is there a recognized VIDA procedure for extinguishing ETS light?
'95 855 auto (sold)
'95 855 auto (sold)
You might be able To pass inspection if CEL isn’t on. Ask inspector!
- Has thanked: 316 times
- Been thanked: 531 times
You can clear the codes and hope the DTC doesn't return, but I don't think you can force it off. Unless you use the ETS light "off" command in the "vehicle communication" section and it stays that way... but I'm not sure that will work.
As long as it's not throwing a P-code, you should be okay for inspection. Here in NC as long as your CEL isn't on and there are no current faults, you're good to go. Most inspectors don't worry about SRS, ABS, and other similar lights.
- E Showell
Turned itself off and I passed inspection in any event.
'95 855 auto (sold)
'95 855 auto (sold)
- E Showell
ETS light is back, ugh. Haven't had a chance to scan, but self-extinguished a while back and has returned sporadically.
'95 855 auto (sold)
'95 855 auto (sold)
The 10,000 mile end of life cycle. Slight accelerated.
I think Xmodex warrantees them for life , don’t they?
Yup, Xemodex ETMs are lifetime warranty. From what I've heard, their warranty process is pretty easy and painless as well.
- E Showell
Self-extinguished today.
'95 855 auto (sold)
'95 855 auto (sold)
- 1405 Views
- 676 Views
Last post by jreed
- 32 Replies
- 6776 Views
Last post by aaron1611
- 1047 Views
Last post by shiloh51933
- 10 Replies
- 2687 Views
Last post by erikv11
