upgrade charging system?
shegarty
Year and Model: 1998
Has thanked: 12 times
Been thanked: 8 times
Post by shegarty »
Hi folks, I just installed a new subwoofer to help with low end bass. It was nothing outrageous (a single 12" 300W rms unit) but I am concerned that I might be stressing the charging system. At higher power levels the lights (headlights and dash) dim slightly. Alternator is still putting out about 13.7V during this time (13.8/9V otherwise). Should I be looking at upgrading the alternator or wiring? What options are available?
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
Has thanked: 1613 times
Been thanked: 4078 times
There were both 80 Amp and 100 Amp options for the 1998 year - check and see which one you have to see if the easy upgrade path is there for you.
About $200 plus core of $100 and you need to bring your pulley over to the new one, too.
shegarty
Post by shegarty »
abscate wrote: 20 Nov 2019, 09:39 There were both 80 Amp and 100 Amp options for the 1998 year - check and see which one you have to see if the easy upgrade path is there for you.
Am I looking for specific markings on the alternator itself?
The output is usually labelled on the voltage regulator - I think you can see it with a mirror and light without removing anything,
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
With 100A alternator you don't need an upgrade.
I don't think that you would need an upgrade even with 80A one.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
98RedV70GLT
Year and Model: 1998 V70 GLT
Post by 98RedV70GLT »
Get a capacitor.
90 Q45
shegarty
Post by shegarty »
Looks like I have the 100A version. I am thinking that it might be worthwhile to check connections and clean them up, maybe upgrade the wiring when it warms up a bit. I have also noticed a dip in dash lighting when the malfunctioning SAS tries to engage as well as when the A/C compressor kicks on. Hopefully its not a sign of the alternator or regulator on its way out as this has been happening now for 5+ years.
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
1997 Volvo 850 NA is consuming battery. Found recently installed (October 2019) new battery dead after few days of not driving.
The car started fine after the battery was on trickle charger overnight. Weather temp is between 35º - 55ºF.
The original Volvo 100A alternator is charging at 13.3V during a normal drive with radio and heater running. What to look for?
Happy holidays!
xHeart wrote: 24 Dec 2019, 11:38 1997 Volvo 850 NA is consuming battery. Found recently installed (October 2019) new battery dead after few days of not driving.
Happy holidays!
Current drain - its time to play pull the fuse, measure the current.
An old Analog (analogue in the UK) meter is best for this - superior to digital in oh so many ways.
You should be well under 50 mA (0.050 Amps) drain on a Volvo sitting still, all doors and glovebox closed.
misha
Post by misha »
xHeart wrote: 24 Dec 2019, 11:38 ...The original Volvo 100A alternator is charging at 13.3V during a normal drive with radio and heater running. What to look for?
B+cable from battery to starter(usually).
It should be 13.8-14.2v at idle with headlights,heater and radio ON.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
