'99 V70 Base - Master Window Switch Issue 8638452 Topic is solved
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
So the Shaggin' Wagon's master window switch was decrepit. I had a dead switch with better cosmetics, so I switched the top plates. Now I can lower the front passenger window with the driver's side master, but I can't raise it with the master. Front passenger window raises and lowers fine with the passenger door switch. Any suggestions?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Get a new Master switch. Aftermarket window switches are a exception, other users have reported better quality in aftermarket switches then OEM switches. You can get aftermarket master switches on eBay for ~ $20.00.
E Showell
Post by E Showell »
So there are no tabs to be bent to make better contact, go back to old top, etc?
'95 855 auto (sold)
Has thanked: 1505 times
Been thanked: 3818 times
I’ll check the cache for spares
8638452 Added part number to title
Courtesy of Radiohead
“ you’re a creep,,,,,.youre a weirdo.....you’re so very special, you only fit 1998 1999 2000 P80s
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
SwitchDoctor makes replacements. I still need to return my old one to them - I ran into an issue with the on/off on the bottom having a pin & spring blow through the button.
