The back of the bottle among lots of other specs states that it's recommended for
Toyota T-1V
Mazda JWS 3309
Volvo 97340, 97341, 1161521.
Does that make it suitable for my 01 V70 XC ? I just topped up a little that I lost looking at my B4 servo cover. I'm probably about to drain 4l or so to put in a recon valve body.
Valvoline Import Multi Vehicle ATF
- SuperHerman
- Been thanked: 207 times
I have used it with no problem. It states it meets the specs on the bottle.
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
I'd use it without hesitation.
In reverse chronological order I've used lots of Valvoline MaxLife Dex/Merc LV (the LV is the thing to note here) in these transmissions.
NOTE: This is NOT an old fashioned, cheap Dex/Merc. The LV has to be on the label.
Mobil 3309. A Virginia parts store ordered it by mistake and I bought the whole case.
Wolf's Head Super Universal Synthetic Transmission Fluid
Toyota T-IV from the dealer
I finally exhausted my 14 gallon supply of MaxLife. AutoZone had a 2 for 1 sale a while back.
My next drain and fill will be with Aisin's own branded fluid.
It's available from IPD and eEuroparts and others.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I had it, and had problems with the fluid shrinking too much in very cold weather - the car would not advance, and also difficult to read the level in warm weather (would always show way above the max level despite having the right amount). It's cheaper indeed, but I would fork a little more for a Toyota type IV or for this ones https://www.fcpeuro.com/products/volvo- ... -1161540kt
Try not flushing it all at once, if you have many miles, and drive inside the city for a while to help the transmission adapt faster (as opposed to long highway drives)
