P0014
Wardhill
Year and Model: 2001v70 xc
P0014
Post by Wardhill »
I get a p0014 code after several miles . 50 -100 miles varies. The vvt valve was replaced at one point due to spliced wires
- Pete -
Has thanked: 80 times
Been thanked: 175 times
Post by - Pete - »
Posting a few more details will really help us help you. Miles, year, model, engine etc. I’m guessing it’s a single VVT engine?
viewtopic.php?f=9&t=89156&hilit=P0014
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
Wardhill
Post by Wardhill »
I’m sorry it’s a 2001 XC70 190k
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
Check the timing marks.
Wardhill
Post by Wardhill »
I can drive 60-80 mph all day long and no cel but as soon as I slow down to a crawl the cel comes on. Is this a sign of the timing being off?
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Check the engine oil condition first. The oil pressure is lowest when the engine slows down.
ECM-644A (P0014) Camshaft reset valve. Slow control. Permanent fault
Diagnostic trouble code (DTC) information
Condition
Diagnostic trouble code (DTC) ECM-644A is stored in the engine control module (ECM) if the camshaft is not in the correct position. The engine control module (ECM) registers this as a fault as soon as the engine is started.
The engine control module (ECM) registers a fault and diagnostic trouble code (DTC) ECM-644A is stored in the engine control module (ECM) if the camshaft position (CMP) sensor flanker is not correct in relation to the engine speed (RPM) sensor.
The engine control module (ECM) registers a fault and diagnostic trouble code (DTC) ECM-644A is stored in the engine control module (ECM) if the camshaft does not rotate quickly enough in response to the control signal.
Substitute value
the variable camshaft is disabled
Possible source
Faulty position
  • camshaft belt has jumped out of place on the cogs
    defective reset valve
    mechanical fault in the Variable valve timing (VVT) unit
Faulty control
  • defective camshaft position (CMP) sensor
Control too slow
  • open-circuit in signal cable
    open-circuit in power cable
    contact resistance
    short-circuit to ground in signal cable
    short-circuit to supply voltage in the signal cable
    low oil pressure
    poor oil quality
Fault symptoms
poor performance
Wardhill
Post by Wardhill »
Oil has been changed twice with mobile one 5 -30 wgt.fully synthetic . Costumes very little oil
Has thanked: 1502 times
Been thanked: 3817 times
vtl wrote: 23 Dec 2019, 08:43 Check the timing marks.
It’s probably 1-2 teeth off
