P0014
- - Pete -
- Has thanked: 80 times
- Been thanked: 175 times
Posting a few more details will really help us help you. Miles, year, model, engine etc. I’m guessing it’s a single VVT engine?
viewtopic.php?f=9&t=89156&hilit=P0014
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- RickHaleParker
- Been thanked: 958 times
Check the engine oil condition first. The oil pressure is lowest when the engine slows down.
ECM-644A (P0014) Camshaft reset valve. Slow control. Permanent fault
Diagnostic trouble code (DTC) information
Condition
Diagnostic trouble code (DTC) ECM-644A is stored in the engine control module (ECM) if the camshaft is not in the correct position. The engine control module (ECM) registers this as a fault as soon as the engine is started.
The engine control module (ECM) registers a fault and diagnostic trouble code (DTC) ECM-644A is stored in the engine control module (ECM) if the camshaft position (CMP) sensor flanker is not correct in relation to the engine speed (RPM) sensor.
The engine control module (ECM) registers a fault and diagnostic trouble code (DTC) ECM-644A is stored in the engine control module (ECM) if the camshaft does not rotate quickly enough in response to the control signal.
Substitute value
the variable camshaft is disabled
Possible source
Faulty position
poor performance
Condition
Substitute value
Possible source
Faulty position
- camshaft belt has jumped out of place on the cogs
defective reset valve
mechanical fault in the Variable valve timing (VVT) unit
- defective camshaft position (CMP) sensor
- open-circuit in signal cable
open-circuit in power cable
contact resistance
short-circuit to ground in signal cable
short-circuit to supply voltage in the signal cable
low oil pressure
poor oil quality
poor performance
- Has thanked: 1505 times
- Been thanked: 3817 times
