07 XC70 what kind of engine coolant?
- shiloh51933
- Year and Model: 04 XC70/'98 V70XC
- Has thanked: 28 times
- Been thanked: 17 times
Re: 07 XC70 what kind of engine coolant?
Pento Frost NF
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
Durenol
- Year and Model: Volvo 2007
- Been thanked: 3 times
So anyone have suggestions for actual brand+type besides "the orange stuff"? Do I want IAT or OAT or HOAT or what? Silicates or no? Does it matter if it's PG or EG? etc. My book doesn't tell me anything.
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
I'm on another continent so I can't recommend anything. Except either get Volvo's since that's what you probably have or get anything that says on the label it's ok for aluminum engines and replace it all. Personally I bought the cheapest ready mix that was available in my area and flushed the old one out.
- Has thanked: 1502 times
- Been thanked: 3817 times
Sorry - Orange stuff is DEXCOOL which is in any auto store or big box (ugh) store with an auto section.
If you are in a climate which is only dipping to 32F or so, water is fine for top off
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
Coolant contains a lot of additives, like corrosion inhibitors and dispersants. Plain water or even old, degraded coolant will eventually kill engine. Of course, this is a very slow process that takes years.
Durenol
OK that looks to be a with-silica type. Says it's "bright blue" so I guess it's HOAT too? (They don't say). Doesn't look like this is popular here, I'll have to call around.
Well I'm assuming that a lot of the brands are probably world-wide for the most part. All I have to do is call the local shops and ask if they have it, the worst that can happen is they say no.
The only places that stock the official stuff are the dealers. They're going to hit me for $35/gal after tax but it looks like I might not have a choice if I can't find anything else.
Dexcool and Pentosin make multiple different types of coolant/antifreeze though, can you be more specific about which one to use?
Yeah I'm only concerned with getting to the store and back whereupon I'll mix it properly. I'm not going to run it that way permanently.
- shiloh51933
Durenol wrote: ↑24 Jan 2020, 09:39OK that looks to be a with-silica type. Says it's "bright blue" so I guess it's HOAT too? (They don't say). Doesn't look like this is popular here, I'll have to call around.
Pento Frost NF is made by Pentosin, I believe Pentonsin manufactures the coolant for Volvo branded bottles.
Yes it's a nice blue color, can't be mistaken for any other color.
- shiloh51933
This should answer any questions in reference to this product.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Same here, and it's concentrate which means you will add another gallon of distilled water ($2 from Walmart Pharmacy) and you have all the needed coolant for under $25USD and you know it's the right type for your car. While there, I would never use tap water in these engines, not even to 'flush' them with that garden hose. In many areas the tap water has high amounts of calcium carbonate dissolved in it which only waits to deposit inside the engine and block coolant passages - remember that the heater core inner tubes are very thin.
- Rattnalle
Surprisingly little is actually. Or if they are they sell completely different products on different continents. And especially if you like me buy the chains own brand product with no idea who's actually making it.
