1999 2000 MY - The "Bastards" Draft Info Thread
Has thanked: 1497 times
Been thanked: 3810 times
Re: 1999 2000 MY - The "Bastards" Draft Info Thread
Recent thread - FWD cars have different driveshafts and hubs, and of course, go to the M8 14 mm hex bolt instead of the 36 mm axle socket.
The hub bolt is TTY and must be replaced each time. ABS errors will result if you don't.
The wheel liners in the front are unique to these model years per this thread
viewtopic.php?f=1&t=86120&start=10
Brake booster change in MY 1999
Argh.
1999- takes the 9485170 so I’ll have to find my 1999 stash
-1998 shows 9438037 , no longer available
1993-1998 9438036 no longer available
abscate wrote: 19 Apr 2017, 23:59 Traction control went from TRACS to STC
Mattymoo lists different part numbers for the ABS module.
I measure master cylinder ports of
Front 13mm
Rear 13mm
on my 1999 with STC and MT
Brake master cylinders on these cars are 1999 2000 MY only
Thread here
viewtopic.php?f=1&t=75878&p=404163#p404163
Discussed here
viewtopic.php?f=1&t=78410&start=3540#p547269
1999 uses a P2 harmonic balancer with the roll pin more offset to one of the Mount holes
The NA 1999 have been found with the earlier 1998 harmonic balancer
The replacement part from Volvo comes with both roll pin holes so it is universal.
New improved windshield washer nozzles per Professor Potato
viewtopic.php?f=1&t=94396&start=10#p550522
Part number change of lower radiator hose to accommodate angled water pipe, not interchangeable with -1998 pipe
viewtopic.php?f=1&t=94810
smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
We should compile all of your work into one master post!
07 V50 T5 AWD M66 ~146k miles
volare
Year and Model: 1999 V70R
Has thanked: 59 times
Been thanked: 4 times
Post by volare »
smacknab wrote: 07 Aug 2020, 07:50 We should compile all of your work into one master post!
I'd be lying if I said I hadn't considered condensing and printing out all of the info in this thread so I'd have a 'manual' stashed in the glove; The Falcon is smack in the middle of the Bastards manufacturing point (M/Y '99, Mfg Oct '98) and without some of these tips I'd never have figured out which part I needed, or at the least spent way more time and $$$ than I needed to and a LOT more cussing...
'99 V70R 180,500+ (FOR SALE)
'06 Baja
'77 Aspen
'99 Honda Rebel
~The Hooptie Herder~
smacknab
Post by smacknab »
Many of these I dealt with, or Steve chimed in before the wrong part, so Im with you. The harmonic balancer note is the outcome of me trying three different parts from FCP.
