Has thanked: 292 times
Been thanked: 765 times
If you decide to junk it, I need one of these (left side of the diode) in black Image
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
erikv11 wrote: 10 Mar 2020, 14:47 If you decide to junk it, I need one of these (left side of the diode) in black Image
Hot Glue Gun and quick setting in place will hold you till the diode or you lose the part.
MoVolvos
Post by MoVolvos »
Keep this in mind when looking at CL?
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
You would be out of luck again. Both are missing on this one.
I can keep an eye out for one in black when I raid the local self service yard.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Probably a bad head gasket... time for a compression/leakdown test. I don't think cracked liners will cause oil and coolant to mix... typically that just burns coolant. That said, I wouldn't be surprised if that's an issue too once you get the head off.
If you choose to fix it, my suggestion is a 2005-2009 2.4 T5 engine... nice bolt-in upgrade.
RickHaleParker
bmdubya1198 wrote: 10 Mar 2020, 20:18 Probably a bad head gasket... time for a compression/leakdown test. I don't think cracked liners will cause oil and coolant to mix... typically that just burns coolant. That said, I wouldn't be surprised if that's an issue too once you get the head off.
I hope it is just a head gasket. Ordered a replacement compression tester. Could not find one local with a deep well extender.
That would be the B5244T5.
Exact same engine as the B5254T4 S60R/V70R except the bore is 81mm vs 83mm and different injectors.
Both engine have the Borg Warner K24 turbocharger.
B5254T4 : 296 hp at 6000 rpm, 258 lb⋅ft of torque at 1950–5500 rpm (1)
B5244T5 : 256 hp at 5500 rpm, 260 lb⋅ft of torque at 2100 rpm.
I wonder what the B5244T5 would do with the B5254T4 software and injectors.
The B5244T5 was also used in the 2005 - 2007 V70 T5.
(1) torque limited.
MoVolvos wrote: 10 Mar 2020, 15:47 ...
Thanks, good idea to put it in place temporarily.
RickHaleParker wrote: 10 Mar 2020, 18:21 ...
If you get to it, thank you! It's on my list but trips to the yard are very few for me.
'06 S60 R, 197k
- Pete -
Has thanked: 80 times
Been thanked: 175 times
Post by - Pete - »
Who can I commission to go grab this for me?
It’s literally 15 miles from my home but I’m 1800 miles from either!
https://minneapolis.craigslist.org/dak/ ... 70418.html
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
jreed
Has thanked: 352 times
Been thanked: 192 times
Post by jreed »
Some stunning plumbing.
https://www.ebay.com/itm/2004-Volvo-V70 ... SwNIheaCRk
Screen Shot 2020-03-11 at 7.07.43 AM.png (862.89 KiB) Viewed 626 times
bmdubya1198
- Pete - wrote: 11 Mar 2020, 02:44 Who can I commission to go grab this for me?
That's a good one... some minor front end repair and you'll be back on the road.
RickHaleParker wrote: 10 Mar 2020, 22:01
(1) torque limited.
It would probably handle it very well, it's a common upgrade for the R. You get the same head as the 4T4 with thicker cylinder walls to support the power and avoid cracked liners. Same forged rods as the 4T4 as well.
