P2 lift kit and engine wire harness
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
There's a Volvo fellow on ebay who does a hand made mild lift kit for S60/V70/XC70 P2 that does not kill CV joints:
https://www.ebay.com/itm/233520779730
The kit is cheaper, fits better (strut mount bearing spacer is CNC-machined) and has more subframe spacers than in other kits.
He also makes a very affordable replacement engine harnesses, for 2.4T and 2.5T:
https://www.ebay.com/itm/Volvo-2-4T-ign ... 3476746840
https://www.ebay.com/itm/Volvo-2-5T-ign ... 3464604207
Check it out!
kklepack
Year and Model: 2016 XC60
Has thanked: 12 times
Been thanked: 5 times
Post by kklepack »
Any idea if one of the harnesses will work on 1999 v70R 2.3 engine? I have VVT with new connector. Perhaps 2.4?
vtl
Post by vtl »
Does it have same coil packs like 2.4T/2.5T engines use? I would say "yes" then.
What engine designation is it? I can look in EWD if the colors match.
- Pete -
Has thanked: 80 times
Been thanked: 175 times
Post by - Pete - »
Very neat find VTL!
That would be an easy install as well.
A lot like how the hillbilly’s do body lifts to their old trucks.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
vtl
Post by vtl »
I have a similar lift kit installed in my XC70 (made myself, but the principles are similar). Love it!
In fact, with the lift and BFG KO2's it is hands down better in snow than my new Tundra TRD Offroad, which is a joke: "offroad" in Tundra is just a sticker.
- Pete -
Post by - Pete - »
Can you share a side shot of it?
That Russian kit looks good enough to tempt me into doing it.
Are you sway bars bigger than stock?
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
kklepack
Post by kklepack »
vtl wrote: 11 Mar 2020, 08:38 Does it have same coil packs like 2.4T/2.5T engines use? I would say "yes" then.
Not sure on engine designation, but it has same coil packs as 2.5 and 2.5 engines.
vtl
Post by vtl »
With the springs settled down in a few days:
In action:
I'm going to upgrade rubber from stock 215/65R16 to 235/70R16, lift should allow that.
Sway bars are XC90/front and V70R/rear. The car was also converted to Nivomats.
vtl
Post by vtl »
kklepack wrote: 11 Mar 2020, 09:44Not sure on engine designation, but it has same coil packs as 2.5 and 2.5 engines.
It will fit if you dare to trace wires to coil packs in case the colors do not match.
What about VVT solenoid? Same connector? Or you can reuse your old one.
kklepack
Post by kklepack »
I have this type connector for VVT and I assume I can reuse it.
Also, I got this info from his ebay add: "Please check and inform the type of solenoid connector when ordering" so I guess he can attach correct connector?
Screenshot from 2020-03-11 10-52-56.png (68.73 KiB) Viewed 1064 times
