Has thanked: 1498 times
Been thanked: 3810 times
Get working on those bolts. After 20 years of Boston, they will be Charlie Foxtrot Stuck
On reflection, I think I would Dremel them off at first sign of problem. Nuts are on bottom, and bolts on top. Replace all of these, of course, with Hardware from Lowes real hardware from Volvo.
2 #7 987186
4#8 985358
4 #9 3546077
$40 of Volvo hardware Nirvana.
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
....hardware from Lowe’s. ..
Haha!
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Yeah, but that's like $10 at Lowe's! Lol
smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
Replaced my control arms because it's the only thing I haven't touched on the suspension at this point and I burnt the boot last weekend with the torch.
Replaced front rotors and pads with FCP lifetime warranty because my friend and I messed up and put the pads in backwards and messed those up too.
Also replaced one rear inner trailing arm bushing which apparently was totally disintegrated. It was a bit of a pain.
07 V50 T5 AWD M66 ~146k miles
Ok, you got me. How do you put pads in backward? Come clean and ye shall be absovolvoed
bmdubya1198
Also curious how that happened! My cousin in FL had the brake pads put on backwards on his CTS once a few years back... the DEALER did it! Fortunately he does his own work now.
smacknab
Post by smacknab »
Honestly it was just rushing after doing my entire suspension and anxious to test it out. I decided to replace the knuckle on that side (the one I had drilled into) and so I had taken everything apart and yeah just I super dumb mistake. So glad I ordered the brakes from FCP.
Did both my inner trailing arm bushings- one looked like this, so I'm glad I did these! At the alignment shop now, excited to have all of this done
I harvested a nice Volvo cat and exhaust fromClarke the 1998. A brake booster , and the OXS sensors
BlackBart
Post by BlackBart »
abscate wrote: 13 Mar 2020, 23:38 Ok, you got me. How do you put pads in backward? Come clean and ye shall be absovolvoed
I would think it would make a lot of nasty metal on metal noise!
99commutervolvos70
Year and Model: 1999 S70 GLT
Post by 99commutervolvos70 »
Replaced the Front Brake pads and Rotors on my '99 GLT
I went with Textar again, Since Powerstop dropped the ball and sent the wrong pads.
I really wanted to see If the powerstop pads kick out less dust...
