2001 V70XC - 200,000 Miles Makeover Topic is solved
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
- Pete - wrote: 19 Mar 2020, 13:48 I forgot something - you can use I believe it is a 10mm ratcheting box end wrench on the shank of the T-55 to get the plug out of the exhaust VVT hub. Ultimately you’ll need to move the wire loom to get an accurate torque on the T-55 bolt that requires 88# torque though.
Thank you for sharing wire loom removal pix.
I'm all set to do the work. I will start with oil pump service.
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
That's the ticket. Just don't crank those puny bolts down and sheer them off inside the camshaft.
xHeart
Post by xHeart »
BlackBart wrote: 20 Mar 2020, 12:16 That's the ticket. Just don't crank those puny bolts down and sheer them off inside the camshaft.
Camshaft tool looks straight forward. I took a while for this beginner.
Now reached the oil pump, gave it a simple green 50/50 mix bath. I can turn the T-30 with stripping for next step.
xHeart
Post by xHeart »
Is there a special method of cleaning the oil pump?
- Pete -
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
Just make certain you get all the old gasket material off. I used a dollar store kitchen sink scrubby/yellow foam thing. You don’t want to abrade the surface too much. Other than that just spray it out with brake parts cleaner & blow dry with compressed air if you can. Or dunk it in your simple green solution & let dry.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
xHeart
Post by xHeart »
The paper seal was crisp - crumbled in to pieces. Watching a cleaned pump can be a joy in itself -- a bath in 50/50 mix of simple green.
- Pete -
Post by - Pete - »
I agree! When you look at its design & see how it works it is very evident why these pumps are good to 500k & beyond.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
xHeart
Post by xHeart »
Orange cone is a magical tool.
I installed the pump first and then the crankshaft seal using the magical cone.
- Pete -
Post by - Pete - »
:lol:
How many tries did it take you?
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
xHeart
Post by xHeart »
- Pete - wrote: 21 Mar 2020, 22:32 How many tries did it take you?
The four T-30 screws were coated with anaerobic sealant at the screw head.
The slit on the cone is a clue to watch as the seal transfers -- generous lubrication and 2 tries. Here is a set up of Pete Method:
