2004 S60R Wheels.
- Pete -
Has thanked: 80 times
Been thanked: 175 times
Re: 2004 S60R Wheels.
Post by - Pete - »
RickHaleParker wrote: 21 Mar 2020, 18:37
Eight months ago, did you miss this or pass them over? FS - Set of 4 17x7 Arrakis Wheels - $100 - IN He might still have them.
Those (your CL find) look incredibly unbitten by curbs. Nice find Rick! Rubber's what 2-3/32"? The Al-you-min-ee-yum (& center caps) is worth $250 easy in that condition.
Have you had the front bumper skin off yet?
Just curious if everything is still there for the fogs.
IN is a bit of a hike from MN. $100 is doable though.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
- Pete - wrote: 21 Mar 2020, 22:42 Those (your CL find) look incredibly unbitten by curbs. Nice find Rick! Rubber's what 2-3/32"? The Al-you-min-ee-yum (& center caps) is worth $250 easy in that condition.
Took a bobby pin measured the tread depth, got 8/32", Virgin is 10/32" will try to find my depth gauge and get a more precise measurement. The tires look like new.
I have not had the bumper off and do not know the status of the fog light hardware. I can get fog lights at the local LKQ for $10.00 each. Last time I got two Fog lights for the C70 left the hardware attached on got charged $20.00 total. That is a whole lot better the the $240.00 a pair online for used. My C70 has the rare round fog lights.
There are way to ship wheels cheap. You just need to know how the carrier's system works, how to pack them, what to say and what not to say. If you poke around you can find the howto online.
- Pete -
Post by - Pete - »
If you have a hard time coming up with R projector fogs let me know.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
RickHaleParker
- Pete - wrote: 21 Mar 2020, 23:53 If you have a hard time coming up with R projector fogs let me know.
Getting the motor sorted out is next on the list.
The 2004 - 2007 S60R / V70R fog lights looks like the same fog lights that my '98 C70 has but different mounting brackets. I had to go all the way to Oklahoma City to get the last pair.
- Pete -
Post by - Pete - »
So it was a roller in other words?
I was curious why the rotors were still so rusty.
My fogs are complete w/brackets. Lenses could use some clay & elbow grease. The stock fogs aren’t great, but better than nothing. I replaced my entire units, brackets & projectors w/PIAA led.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
RickHaleParker
- Pete - wrote: 22 Mar 2020, 00:32 So it was a roller in other words?
It is a $500.00 mechanics special. It has been sitting for some time. Everything is pointing toward upper end work. Antifreeze in oil pan, multiple cylinders and charged air pipe. It does have the Atacama interior.
I use wet and dry 2500 - 3000 sandpaper then clear coat the lenses. The trick to sanding is to keep it wet, wash periodically and sand in a circular motion. If you got deep scratches make a paste out of Cerium Oxide and apply with a buffer.
You got the IPD PIAA upgrade?
- Pete -
Post by - Pete - »
Nice, they aren’t scratched, just pitted as usual from road debris.
I did a dual LED fog setup. I got the IPD kit for the original fog holes in “driving beam 6000k” when it was on clearance. I watched the price forever it seemed! I have the euro style grills, so I made spots/plates for a second pair of fogs & installed them (in “fog beam 6000k”) to more fully illuminate the road immediately in front of the car.
Expensive, yes, but the light output at night is really what I was after. I am still unsure if I like the look of it, but I forget about that when I’m driving at night (rare). My CEM is also set so my fogs stay on with high beams.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
RickHaleParker
From another MVS post. 2004 V70R. Wheels are 17" Konig Oversteer .
RickHaleParker
- Pete - wrote: 21 Mar 2020, 22:42 Just curious if everything is still there for the fogs.
Left fog light grill is missing look in, felt around could not find any mounting hardware.
Popped the right grill out, same results as the left.
