You’re fine, with the cams locked there will be no valve contact made.
Just grab the crank gear with your hand and roll it back so it’s lined up & carry on as usual.
2001 V70XC - 200,000 Miles Makeover Topic is solved
- - Pete -
- Has thanked: 80 times
- Been thanked: 175 times
Re: 2001 V70XC - 200,000 Miles Makeover
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- - Pete -
Thanks, I should have been more clear.
Moving only that much w/cams locked no contact will be made. And if so not enough force to bend anything.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
Once I broke my DIY 1/8" mild steel cam lock tool and thus applied the full force required to torque the camshaft bolt onto valves and piston - nothing bad happened, besides -$140 for the forged steel lock tool
Nothing to worry about at all if your cam/crank setup moved or even piston touched the valves. It will not cause any damage.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 113 times
- Been thanked: 115 times
Whew!
It is now adjust back to aligned marks. How will it stay in place with torque wrench when harmonic balance goes on?
- Has thanked: 1506 times
- Been thanked: 3818 times
Perfectly if you lock the crankshaft per the Volvo procedure
You can also temporarily replace the M6 bolts with cheap long bolts and then counter hold with a bar
xHeart
Learning the use for power tools, and restored few items in addition to:
- Hub/Pulley #1275363 (Volvo)
- Intake Camshaft Seal -- Sealing Ring #9458309 (Volvo)
- Exhaust Camshaft Seal -- Sealing Ring #9458309 (Volvo)
- Engine Camshaft Plug Cap #1397381 (Volvo)
- Engine Expansion Plug #1275364 (Volvo)
- Oil Pump Gasket Kit #274260 (Volvo)
- Timing belt components - belt, pulley, and tensioner
- Waterpump (Aisin)
- Serpentine belt - belt and tensioner
Why does torquing feels like a stressful circus?
After reading few hands-on, and checking VIDA, the t-belt was installed while holding vvt hub in full-advance (aka preload) -- the three 8mm bolts were loosen at this install to reset timing marks. Once the belt was on, and concurrently holding hub in full-advance position, VIDA says to apply tensioner's steps -- a juggler like experience.
Next step is Pete's suggestion to verify timing before s-belt goes on -- a cool discovery step for me.
Here is a progress pix:
- Waterpump (Aisin)
xHeart
Getting closer to installing the upper engine stabilizer mount. The long flange screw is 10x1.5x70 with ring of material. Here is the pix of location at the back of the block where it fastens the mount -- a pass through thread, there is no bottom. How to restore so it can take torque?volvolugnut wrote: ↑18 Mar 2020, 18:47 It may be the tall screw has bottomed on the full thread form in the hole. Do we know if this screw should be longer than the others? What I am trying to say is the screw bottomed out in the threaded hole and the last two threaded 'tapped' the incomplete threads to reach full depth.
If this happened, there should be no real damage to the screw or the tapped hole. Measure the thickness to be clamped by this screw and determine if it is too long. Inspect the bottom of the hole to see if there is more than minor thread forming by the screw.
Most taps have a bevel on end of the thread of several threads before they create the full thread form that will match the screw.
volvlolugnut
