'99 V70 FWD, Auto, Base, 235K miles -- Toasted PNP? Topic is solved
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
So, let's have your opinions. The Shaggin' Wagon is giving me the occasional no-start. I know it isn't the battery since all dash lights light up like the proverbial Xmas tree. I turn the key and get lots of lights and no, and I mean zero sound. Last time this happened was about a week ago after a gas fill up. I rowed the shifter back and forth about 20 times rapidly and it restarted. The shift lock release button was incredibly difficult to depress.
Sound like a dirty/failed/failing PNP switch? Inquiring minds want to know.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Has thanked: 1505 times
Been thanked: 3818 times
You can try jumping it with the under hood starter but be aware that the connector is upstream of the PnP
That would eliminate ignition switch , electrical part though. I have a spare one of those, by the way
E Showell
Post by E Showell »
I don't think the starter is dead since I'm pretty sure the original starter has been replaced (without removing the fan shroud) -- and for my next trick, I will be extracting the transmission through the rear tail gate . . . .
'95 855 auto (sold)
Has thanked: 1850 times
Been thanked: 1712 times
what about the antenna ring. That inhibits the starter from running. Try cleaning the contacts to start with and check for cracking in the plastic casing causing breaks in the circuit.
scot850 wrote: 26 Mar 2020, 12:32 what about the antenna ring. That inhibits the starter from running. Try cleaning the contacts to start with and check for cracking in the plastic casing causing breaks in the circuit.
I think the Shagging Wagon is a 99 with DENSO - Immobilizers inhibits starting but not cranking.
E Showell
Post by E Showell »
Steve -- Correct -- DENSO-equipped.
'95 855 auto (sold)
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
When it will not crank and start in "P"...start it in "N".
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
E Showell
Post by E Showell »
Tough to depress the shift lock release button to move the shifter.
'95 855 auto (sold)
misha
Post by misha »
EU cars doesn't have that button.
Doesn't it suppose to override the gear selector?
It should not have anything to do with p'n'p switch.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
E Showell
Post by E Showell »
Won't start in neutral. Not even turning over. Feels like no juice getting to starter, or bad starter.
'95 855 auto (sold)
