Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 333 times
Post by Chuck W »
Cookeh wrote: 03 Apr 2020, 13:19
Chuck W wrote: 03 Apr 2020, 06:03 We also dyed all of the upper interior pieces to the dark grey.
What dye did you use? I've been tempted to do similar!
I've been using the SEM ColorCoat stuff. I used the "Graphite" color on these.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Cookeh wrote: 03 Apr 2020, 13:19 What dye did you use? I've been tempted to do similar!
Volvo leather dye by Volvo interior code. Takes the guess work out. Anybody wanting to go Atacama?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Engine's out of the V70! Just waiting on some parts now. 2 of the engine mounts are TOTALLY shot.
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
bmdubya1198 wrote: 03 Apr 2020, 19:10 Engine's out of the V70! Just waiting on some parts now. 2 of the engine mounts are TOTALLY shot.
You are fast and work clean. How long would it take to replace the clutch on an 08 C30 :wink: ?
bmdubya1198
MoVolvos wrote: 03 Apr 2020, 20:03
Over a couple days, probably 8-10 hours of actual labor. I would probably handle that by removing the engine and transmission as a whole like I did here, this seems to be easier than dropping the trans from underneath. Then again, P1s may be easier that way.
MoVolvos
Post by MoVolvos »
bmdubya1198 wrote: 03 Apr 2020, 21:12
Well, I guess I won't drive it over to Charlotte for you to work in it :D. I did find a video on this and the preferred method is too drop it from underneath. Thanks, perhaps my son and I will tackle it when it's time. Getting there however.
Has thanked: 1503 times
Been thanked: 3817 times
Mo....get the 150 buck picker from Harbor freight and take it up and out.
Ive done both now and engine transmission out seems harder, but it isn’t
Our esteemed Professor or Potatoes tried to tell me this once but I was tone deaf and stupid
bmdubya1198
abscate wrote: 04 Apr 2020, 14:55 Mo....get the 150 buck picker from Harbor freight and take it up and out.
Agreed... engine and trans out the top is by FAR the easiest way I've done it. I've pulled the transmission from underneath twice, pulled just the engine once, and pulled the engine and trans together twice now.
That said, the reason I mentioned it before is that I'm not sure if the P1 has the clearance from up top. If so, it's a pretty easy job doing the clutch. It's not particularly hard to get the transmission out of the bottom, but it's a bit of a pain lifting it up and down.
You have to add all the subframe removal steps to lower it down , and those steps can really bite you hard. Snapping off the subframe bolts being a leading example
bmdubya1198
That's always a possibility too. Fortunately I don't deal with a lot of rusty cars, and I haven't had an issue with snapping a subframe bolt yet.
