Stuck Rings?
RickHaleParker
Been thanked: 958 times
Re: Stuck Rings?
Post by RickHaleParker »
abscate wrote: 06 Apr 2020, 19:08 Half acetone half ATF by volume.
That is DIY penetrating oil.
DIY Seafoam is: 4 parts Diesel, 2 parts Naphtha, 1 part IPA (Isopropyl Alcohol).
Has thanked: 293 times
Been thanked: 765 times
RickHaleParker wrote: 08 Apr 2020, 06:01
You (us) guys and your (our) cryptic posts ...
abscate are you saying you posted the wrong thing, you actually used DIY Seafoam? Or indeed do you recommend DIY penetrating oil?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Has thanked: 1507 times
Been thanked: 3824 times
I used DIY penetrating oil - acetone/ATF
I have done this on 3-4 engines in the past - mostly air cooled VW stuck horizontally opposed motors.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
My first car was a '68 Type III (Squareback for you non VW enthusiasts). Non runner (stick) bought from my folks for $1 with no functioning reverse. Sweet ride.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
RickHaleParker
E Showell wrote: 08 Apr 2020, 15:06 My first car was a '68 Type III (Squareback for you non VW enthusiasts). Non runner (stick) bought from my folks for $1 with no functioning reverse. Sweet ride.
My first car was a '67 Karmann ghia. Both doors would fly open when backing up. Had a blast with it.
befarrer
Year and Model: 1998 V70 AWD
Been thanked: 24 times
Post by befarrer »
I may have to give it a try since I have the car parked for another couple weeks and I am almost due for an oil change.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
rguzz
Year and Model: 1996 850 turbo
Post by rguzz »
Great looking car. Wish I ever owned a car that used .5L oil every 4k km's, including brand new ones. You might make it easy and start with Marvel Mystery Oil, (? mineral spirits and ATF no fuss) directly in cylinder 2, let sit for 1-2 days, pull the fuel pump relay, crank a bit, add .5L to the fuel, run it well on a warm/hot day. This can avoid an oil change though you say it's needed anyway. Do not intend to start a Marvel debate. Just a thought. Other option, god forbid, would be to do nothing, drive it on a few long trips, stop thinking about it, check compression again in a year. I would likely take the obsess over it option myself, change the oil a zillion times, serial compression tests, whatever. But is that best?
befarrer
Post by befarrer »
I'm going to use what I have here, instead of acetone, I'll use a diesel/atf mix. Marvel mystery oil here is almost non existent.
98 V70 GLT AWD
05 VW Golf TDI
befarrer wrote: 10 Apr 2020, 07:53 I'm going to use what I have here, instead of acetone, I'll use a diesel/atf mix. Marvel mystery oil here is almost non existent.
You need something thin to get the oil into the cracks/crevices/nooks/crannies.
Paint thinner
Charcoal lighter fluid?
Gas or, even better, petrol
hardware store should have acetone and paint thinner
