Three years ... pull the dipstick. If there has been coolant in the crankcase for three years. It will need a lot more then a top end rebuild.
- RickHaleParker
- Been thanked: 958 times
- Has thanked: 305 times
- Been thanked: 517 times
Yeah, that’s a very good point. The last time a car I bought “just needed a head gasket” it turned into a new engine. The cylinder walls were horribly rusted when I pulled the head off.RickHaleParker wrote: ↑09 May 2020, 22:38Three years ... pull the dipstick. If there has been coolant in the crankcase for three years. It will need a lot more then a top end rebuild.
The problem is that people use water in the cooling system to save money since the HG is leaking, then if it gets into the combustion chambers and sits for an extended period of time, bad things happen. Same goes for the crankcase.
V70 GLT project in Winston Salem NC.
Looks decent, it could probably be had for under $1k. I’d probably go pick it up if I had any more space
- E5E973AC-1303-48FC-BD28-D67A5F9E4A8D.jpeg (550.87 KiB) Viewed 594 times
- smacknab
- Has thanked: 97 times
- Been thanked: 43 times
Thought someone might be interested in the interior seats on this. If it's well maintained might be a good parts car. Or good enough to drive around on its own idk.
https://m.facebook.com/marketplace/item/
590305891614169/?ref=browse_tab&search_query=volvo&tracking=%7B%22qid%22%3A%226825788050307156633%22%2C%22mf_story_key%22%3A%223090482211071949%22%2C%22commerce_rank_obj%22%3A%22%7B%5C%22target_id%5C%22%3A3090482211071949%2C%5C%22target_type%5C%22%3A0%2C%5C%22primary_position%5C%22%3A-1%2C%5C%22ranking_signature%5C%22%3A0%2C%5C%22commerce_channel%5C%22%3A503%2C%5C%22value%5C%22%3A0%2C%5C%22upsell_type%5C%22%3Anull%7D%22%7D
07 V50 T5 AWD M66 ~146k miles
- smacknab
Parts car in NY
/159908382053258/?ref=browse_tab&search_query=Volvo&tracking=%7B%22qid%22%3A%226826813443701618405%22%2C%22mf_story_key%22%3A%222819625551424381%22%2C%22commerce_rank_obj%22%3A%22%7B%5C%22target_id%5C%22%3A2819625551424381%2C%5C%22target_type%5C%22%3A0%2C%5C%22primary_position%5C%22%3A-1%2C%5C%22ranking_signature%5C%22%3A0%2C%5C%22commerce_channel%5C%22%3A503%2C%5C%22value%5C%22%3A0%2C%5C%22upsell_type%5C%22%3Anull%7D%22%7D
- Has thanked: 2658 times
- Been thanked: 1248 times
What a PEACH of a car. 64k miles, service records, great driver's seat leather. Wow.
https://denver.craigslist.org/cto/d/lou ... 01442.html
Volvo S70 sedan
White/ tan leather
Moon roof, alloys, power front seats, climate control a/c and heat, 2 keys, 2 remotes.
Extremely clean inside and out.
Leather is in excellent condition with NO rips or tears.
NO hail damage, NO stars or cracks in windshield.
64 k miles, yes....... that's right only 64 k miles !
This is a unicorn for sure.
An elderly ladies car originally from Texas that was garaged it's whole life and driven very little over it's lifetime.
(Remember the little ole lady who only drive her car to church on Sunday? This is her car !!!!!
The following has been done in the last 2k miles and/or this month:
Complete timing belt service including H2O pump, tensioners, idler, etc. (mileage 62.2k, 12/16)
New spark plugs
Rear engine mount
Upper torque mount
Upper strut springs
4 wheel alignment
R/F door lock actuator
Brake flush
Antifreeze flush
Oil and filter change 4/20
4 new (40k warranty tires) 4/20
This is a Non-turbo, runs on regular gas and averages mid 20's mpg.
1998 is one of the best years for a Volvo.
It is the last year before the coil pacs (drive by wire) and other electronic changes and is the most desirable of the 3 yrs this car was made from 98-2000.
With average mileage of 12k /year, a l998 vehicle should have at least 264.000 miles, BUT this car only has 64k, 200,000 miles LESS!
That's leaves a lot of years of driving left to experience with this car.
Everything has been maintained routinely and all services are up to date.
If you are a true Volvo lover, this is the car for you and the ideal car to put a new driver in.
This is almost like a barn find vehicle.
Asking $4250
Hurry as I know the first person to see the car will buy it.
Remember that this car needs absolutely nothing and ALL services are up to date.
- June
- Has thanked: 523 times
- Been thanked: 261 times
If I had any desire to drive a 850 again, THIS WOULD BE IT! That car is gorgeous! Good options as well. $4K is cheap. You'd spend at least that buying a cheap one and fixing it up. Yet you won't have a clean original like this one.
Being as this is Matthew's 850 site, please one of you enthusiast get this one! It would be a shame for a non Volvo enthusiast to buy this one to run it in the ground... BTW I am aware it's a S70 badge wise. It's still a 850 in my book. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
Agreed on all points, June. $4k is cheap.
Especially a 1998. It's an 850 with a few different pieces of sheetmetal and interior.
I've got the RWD bug, bigtime. If I jump back in (when), it's going to be a RWD wagon.
- June
Yes, being a 1998 no ETM!!! Good ole 850 under the hood! Yet it's had a freshen up as you said Matt. One of us on here MUST buy this one. I normally don't comment on used cars other than posting something interesting I run across. But this car is exactly what you want to see!!!!!!!! I'd hate to see a doofus who should drive a Honda or Toyota buy this and six months later send it to scrap with a blown engine or transmission out of ignorance. June
My Volvo cars owned
1996 960 ordered
1996 960 ordered
