Removing a P80 head and have broken
14 mm six point socket Tekron
14 mm six point deep socket Tekron
Two Pittsburgh extenderS 3/8
Problem is , none of 1/2 sockets will clear the hole in t-he cylinder head
Does anyone have a 1/2 drive six point 14 mm solution they can share
I’ve gotten 11/12 out and the last one stripped, so I’m drilling. No rush
P80 head bolt tools
- Has thanked: 1611 times
- Been thanked: 4072 times
- Has thanked: 312 times
- Been thanked: 818 times
I bought a set of Stanley deep socket six point impact from Walmart expressly for the 14 mm to use on head bolts. It is lower quality so slightly thinner walled and fits in there nicely.abscate wrote: 05 Jun 2020, 07:22 ...
So shop the cheapies. Stanley is not high quality but high enough to get the head job done the three times I needed it. If you can't find one that fits or just prefer it, I can send it to you. Lmk.
- RickHaleParker
- Been thanked: 980 times
Are you sure it is stripped and not broken in two?
Flood the hole with Liquid Wrench and let it soak for a week, keep it the level up.
I snapped one off in a 960. After soaking, a guided left hand drill bit spun it right out.
Active
Past
Past
Bolt head stripped off last one. I am going to take it to a machine shop for that one since I can’t get the whole engine under my drill press easily. I need them to dip the head so no extra trip.
- RickHaleParker
A guide does not need dead precision in this case.abscate wrote: 06 Jun 2020, 04:44 Bolt head stripped off last one. I am going to take it to a machine shop for that one since I can’t get the whole engine under my drill press easily. I need them to dip the head so no extra trip.
For a drill guide:
1. Sleeve the left hand drill bit with a rubber hose.
2. Spin bit and hose in a hand held drill.
3. Sand the hose down to size.
4. lubricate hose.
Active
Past
Past
- Has thanked: 987 times
- Been thanked: 1078 times
It is the day for broken tools. I broke (again) a T40 Torx. It was Craftsman purchased this week. The real world rating is less than 37 Foot-Lb.
- RickHaleParker
Almost forgot ... SK Suregrip sockets. They engage the bolt heads near the center of the flats rather then the corners. Wright's Wrightgrip, Snap-On's Flank Drive, Craftsman's Extreme Grip works the same way. Most impact sockets are designed this way.
Active
Past
Past
