Engine swap
KevinCro
- Year and Model: 2004 xc90
- Has thanked: 7 times
Hey guys. I sourced a good engine from a local junk yard for my 2004 XC90. Ive seen a couple videos about how to remove the engine. The videos I’ve seen either pull the engine out the front or drop it out the bottom. Why couldn’t I just hoist it out the top like normal? Seems like these people went to a lot of extra work. What am I missing?
2004 Volvo XC90 T6 169k miles
- SuperHerman
- Been thanked: 207 times
If you have a hoist it is much easier. That is how the car was assembled - the entire thing just drops down. When I had transmission work done, the shop dropped the entire engine and transmission in a few hours.
Coming out the top on SUVs is tougher because of the added height needed. On my old Range Rover I had to put the car on the lowest jack stands I could find to dip the nose low enough so I could get the cherry picker with engine to clear the frame.
KevinCro
Thanks for the info. Is it possible to pull the engine without pulling the transmission? If not that’s fine, I’m just trying to understand. I have done engine swaps on rwd and 4wd but this is the first front wheel/all wheel drive that I’ve done. If it’s just not possible, or just so hard that it’s not doable, that’s fine. Just would like some guidance before I start taking axles out and what not. Thanks so much.
Masscomguru
- Year and Model: 2010 XC90 V8
- Been thanked: 16 times
- 1164 Views
Last post by MadeInJapan
- 15 Replies
- 5268 Views
Last post by soulvoid21
- 17 Replies
- 6468 Views
Last post by henrysin44
- 14 Replies
- 1050 Views
Last post by jonesg
- 1439 Views
Last post by FLXC90
