I'm only trying to get to the parking brake adjuster screw/nut.
The various videos I can find do not seem to have the same style of console panels around the parking brake lever. They all show a short panel around the base of the lever that can be pried off.
Mine has a long panel (photo below) which I have tried prying, but seems to be stuck along the top of the forward section. How does this come off?
Thanks for your suggestions!
06 v70: how do I access parking brake adjuster? Topic is solved
- Has thanked: 1611 times
- Been thanked: 4075 times
The boot comes out if the hard plastic and reveals the adjusters there.
- ogatrulle
- Year and Model: xc90 2008
- Been thanked: 10 times
So should I just pry along the edge of the boot?abscate wrote: 15 Jun 2020, 18:52 The boot comes out if the hard plastic and reveals the adjusters there.
2006 v70 2.5T; 2008 xc90 3.2
It’s usually sticky from spilled soda , coffee, dead bodies so it’s a bit tough to start
I’ll meander over to my P2 and take a few pics to get the visual in this thread this morning
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Just lift it up gently. I has several small pins at the bottom which easily break, so when placing it back keep a close eye at the bottom while pushing it down, so all pins engage properly - not a big deal if 1-2 break but still
Tut lifts straight up with finger pressure. Plastic fingers go into slotsabscate wrote: 16 Jun 2020, 04:09 It’s usually sticky from spilled soda , coffee, dead bodies so it’s a bit tough to start
After that, lift the brown plastic cover to see the screw
- ogatrulle
I am astonished at how easy it was once I knew where the boot separates. Never would have guessed. I just pulled up on the perimeter of the leather boot at each of the five slot locations.
Here are some additional pictures I took - same setup as abscate's.
View from left: View from right: Stealthy adjuster hiding under plastic cover that flips up:
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
if you find the adjuster doesn't give you the authority needed at the rear wheels, the cables are stretched, I snapped the adjuster in mine.
NOLA from volvo but IPD sells local made ones.
Pictures make a forum rock.
- 725 Views
Last post by MoVolvos
- 1329 Views
Last post by chris11211
- 10 Replies
- 2132 Views
Last post by Mr. Detail
- 1163 Views
Last post by mags98c70
- 21 Replies
- 5644 Views
Last post by j-dawg
