Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
I just picked up a used 20 ton shop press yesterday, so I'm already looking for things to press :)
1999 V70 GLT
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 333 times
Post by Chuck W »
Sveedy wrote: 16 Jun 2020, 09:30 I just picked up a used 20 ton shop press yesterday, so I'm already looking for things to press :)
That is WAAAAAAYY overkill for this, and not even worth the hassle of trying to figure out how to make it work. ;)
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
A shop press is a good excuse to gather up more sockets of various sizes to use as the die to press on parts to be removed.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
I tried to use my 20 ton press for the subframe bushings... it was more work to try to have my cousin hold the subframe with me while I tried to operate the press :lol:
But I love my press... half the things I use it for don't even need that kind of force, but it's just fun to use. Sketchy as hell at times, but effective.
Sveedy
Post by Sveedy »
It is an old American made beast that I only paid $ 125 for. I have a bad habit of buying tools that I might or might not need, if they seem like they could be useful. I'm thinking that the press might be easier than C- clamps for u-joints and for replacing axle bearings and leaf spring bushings on my old full size Jeep pick-up. And it could always be used for cracking walnuts, applying postage stamps etc...
1999 V70 GLT
bmdubya1198
Sveedy wrote: 16 Jun 2020, 11:56 It is an old American made beast that I only paid $ 125 for. I have a bad habit of buying tools that I might or might not need, if they seem like they could be useful. I'm thinking that the press might be easier than C- clamps for u-joints and for replacing axle bearings and leaf spring bushings on my old full size Jeep pick-up. And it could always be used for cracking walnuts, applying postage stamps etc...
Nice score! Mine's a Harbor Freight special, but it gets the job done.
I'll have to try applying a stamp with it...
You can also get creative and do metal embossing by making a male die and a rubber pad to press the die against. 20 tons should work for patterns a couple inches across. I saw a car magazine article where they made a jeep logo this way.
bmdubya1198
Now that would be pretty cool!
Sveedy
Post by Sveedy »
I was just going to say that. I love " non-conventional " uses for things !
1999 V70 GLT
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Sveedy wrote: 16 Jun 2020, 08:18 Chuck - Do those get pressed into the frame ?
I replace them by:
1. Cutting the lower lip of the bushing off with a 70mm hole saw.
Keep cleaning it off and keep it lubed it with 3 in 1 oil.
2. Drop some light oil around the edge of the old bushing and let it soak down between the bushing and frame.
3. Press the bushing out with Press & Pull Sleeve Kit.
The hole is 70mm use a 60/70 and a 70/80 Sleeve.
4. Lube it up good with light oil, both the hole and the bushing.
5. Beat the new bushing into the frame with a rubber mallet.
If you don't have a Press & Pull Sleeve Kit. Find something 70mm in dia. ( 2¾ in). You could probably use it to tap the bushing out. After you get oil down between the old bushing and the frame.
