I’ve found you can get ALL the toothpaste out with a press.
- Has thanked: 1613 times
- Been thanked: 4078 times
I’ve got ahold lower torque rod that I’ve been looking at in the garage too long, calling on me to make a bushingfroa hockey puck.
Anyone in p80 land have one of these?
Volvo 940 2.3l Fuel Injected 1992, 1993, 1994, 1995
Volvo 940 2.3l Fuel Injected Turbo 1992, 1993, 1994, 1995
Volvo 940 SE 2.3l Fuel Injected Turbo 1992
Volvo 960 3.0l 6 cylinder Fuel Injected 1992, 1993, 1994, 1995, 1996, 1997
Volvo S90 3.0l 6 cylinder Fuel Injected 1997, 1998
Volvo V90 3.0l 6 cylinder Fuel Injected 1997, 1998
Need a picture with scale of the ac line hold down clamp
Thread here in the other forum
viewtopic.php?f=2&t=94273
- Has thanked: 317 times
- Been thanked: 531 times
Wow, those are bad! This was the mount in my E39 after it was rear ended. Only damage the car sustained! Well, aside from the broken pedestal, but that was all an easy replacement.
- smacknab
- Has thanked: 97 times
- Been thanked: 43 times
Replaced a torn vac tube from my carbon canister, hoping it solves my evap leak code.
07 V50 T5 AWD M66 ~146k miles
I told it how frustrated I am with my Saab. I also tried to fix some aging wiring issues while troubleshooting the radiator fan.
Owning 5 Swedish cars, all older than 20 years, can teach one a lot about auto repair!
- smacknab
I just seafoam's my 99 na per Mathews instructions and now I'm getting a p0327 code, which other posts here indicate to be a knock sensor wiring code. I reset the code and will see if it comes back on, but has anyone else had similar experiences?
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
Huh, weird. Lucky they're so easy to replace.bmdubya1198 wrote: 19 Jun 2020, 09:09 Wow, those are bad! This was the mount in my E39 after it was rear ended. Only damage the car sustained! Well, aside from the broken pedestal, but that was all an easy replacement.
BMW 540i 2002
S70 Base 2000
- Volvebaker
- Year and Model: 1993 850 GLT
- Been thanked: 12 times
Threw some new Konigs on her
Pull the connector and clean it out well iff the code comes back. I bet it doesn’t.smacknab wrote: 19 Jun 2020, 15:35 I just seafoam's my 99 na per Mathews instructions and now I'm getting a p0327 code, which other posts here indicate to be a knock sensor wiring code. I reset the code and will see if it comes back on, but has anyone else had similar experiences?
