Pcv, breather box help
TyRawr
- Year and Model: 2003 S60 2.5 Awd
- Has thanked: 14 times
I have everything lined up pretty well. Are you in cincinnati? I would love to meet with someone who has some knowledge on this. Would also love a video.
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
Wire wheel the little rust spot, tape off area, spray w/metallic silver rattle can.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- - Pete -
The spring bolt is one of the 3 that retains the turbo heat shield. The galvanized pipe is a hard coolant line that attaches to the turbo & reservoir.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
TyRawr
Well the spring bolts both broke. Is that normal? They didn't move, just twisted and broke. I know I was going the right direction because the other bolts came off? I mean the car is pretty old but idk, live and learn
I'll have to tap it out once its off. No big deal
I'll just have to get new ones.
But both heat shields are off.
And I can't seem to get to the lower bolt on that coolant pipe though. The pipe is right in front of it and really close. Nothing I have to use a 10mm socket will reach in there. Also didnt make much progress with a wrench
- - Pete -
I haven’t had one break, but I’ve always anticipated that particular one breaking every time I’ve put force to it.
The only times I’ve had the coolant & oil pipes off the turbos have been when I’ve also had the bevel gear off. I’m sure there’s a work-around. Maybe SuperHerman, Abscate or VTL will chime in.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- Has thanked: 1613 times
- Been thanked: 4078 times
If those have been in awhile they need heat to be applied for thee -four cycles ( propane, 60 seconds, then 10 minutes cooling) to break the bond.
If you have a stub of stud left you can apply heat to that and use a sharp vice grip to turn it out.
If not, the heatshirld can be zip tied back in
A small 1/4 drive socket , 10 mm will fit on the lower water pipe bolt.
- 4758 Views
Last post by jamadams11
- 13 Replies
- 3540 Views
Last post by nickbw898
- 24 Replies
- 5512 Views
Last post by Darkskies65
- 2036 Views
- 1045 Views
Last post by vtl
