Replace ABS Ring without Alignment?
br0dy519
Year and Model: 2004 XC70
Has thanked: 123 times
Been thanked: 115 times
Post by br0dy519 »
Hi guys,
04 XC70, last year my driver side tone ring rotted through. I followed all prescribed methods and undid 2 nut/bolts holding the steering knuckle to the hub. I then went to my alignment guy and had him do an alignment. He told me at that time last summer that I could have removed the axle to service the tone ring without undoing those bolts and putting it out of alignment. My passenger side ring just went a couple weeks ago (Doh, this should have been a both-sides at the time job!), and I'm racking my brain trying to remember what he said, but I'm having trouble. So I'm here asking does anyone have a method for removing the axle from the hub that won't require another alignment? Thanks,
04s60 2.4
04xc70 2.5t
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
If my memory helps, I think you can remove the axle shaft by detaching only the two lower bolts at the strut - the shaft will barely come out - careful with the small black plastic seal, it needs go back in place because it protects the wheel bearing. You should not need alignment other than the camber setting but you can measure it beforehand (I don't think it's that important), and careful with with the ABS wire, the slightest pull on it it gets damaged (to remove the sensor always push with a screw driver from underneath the sensor) www.youtube.com/watch?v=oF-z2iPgChg
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Post by xHeart »
ABS ring and its function is independent of wheel alignment. But you must do wheel alignment after steering and suspension work regardless. An un-aligned car is self destructive, danger for motorist, and burden on your pocketbook.
br0dy519
Post by br0dy519 »
oragex wrote: 26 Jun 2020, 07:56 If my memory helps, I think you can remove the axle shaft by detaching only the two lower bolts at the strut - the shaft will barely come out - careful with the small black plastic seal, it needs go back in place because it protects the wheel bearing. You should not need alignment other than the camber setting but you can measure it beforehand (I don't think it's that important), and careful with with the ABS wire, the slightest pull on it it gets damaged (to remove the sensor always push with a screw driver from underneath the sensor) www.youtube.com/watch?v=oF-z2iPgChg
Thanks for the video. Those were the two bolts to which I was referring in my original post. I'm going to chalk a mark on them this time. Also for the ABS sensor I always disconnect it and dress it out of the way when doing any work on the front end.
04s60 2.4
04xc70 2.5t
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 603 times
Post by vtl »
You can compress the spring in place and unbolt the ball joint. But really, follow the instructions from VIDA: measure the distance between rear of the strut and front of the knuckle with outer caliper and return it to the same position after repair. No alignment is needed afterwards.
99% of time everything alignment shops are doing is a front toe. You can save your money (and often time) and do it yourself with the Trackace. Around $100 on ebay. With IPD's adjustable rear toe rods it is also easy to do it in rear. Just takes a few more iterations for searching the right thrust vector by feel. Since I replaced my rear suspension with the Nivomats the nearest shop could not align the car properly, they let it sit for a few hours before doing the alignment, and that it enough for Nivomats to sag.
br0dy519
Post by br0dy519 »
I completed the job this weekend. I snapped one of the lower strut bolts, and realized that in the instructions you SHOULD use new bolts anyways. So if you're in Canada and, like me, there's no Volvo dealership for 300km: call up your local Carquest with P/N Y2001849336MTC for a $6 replacement bolt.
04s60 2.4
04xc70 2.5t
Has thanked: 1497 times
Been thanked: 3810 times
br0dy519 wrote: 29 Jun 2020, 06:41 I completed the job this weekend. I snapped one of the lower strut bolts, and realized that in the instructions you SHOULD use new bolts anyways. So if you're in Canada and, like me, there's no Volvo dealership for 300km: call up your local Carquest with P/N Y2001849336MTC for a $6 replacement bolt.
Thanks for the part number reference asan alternative to the Volvo part numbers
985660
982870
