What OBDII Scanner Should I Get?
Volvo Diagnostic Code Lookup
- Has thanked: 1505 times
- Been thanked: 3818 times
Re: What OBDII Scanner Should I Get?
I think you can even get a Bluetooth phone compatible version for 10 EURO or so
esl_97_850_T5
- Has thanked: 18 times
- Been thanked: 27 times
eightfifty2x0,
To answer your question...
I think most USA '96-97 850 owners probably use a scan tool >= 1 time per year.
Since 2012, I needed to use a scan tool multiple times per year (while I owned my USA '96 850 T5 and/or '98 S70 GLT).
If your car has the in-cabin OBDII port, and if you have an available Android phone or tablet, then I suggest...
Cut the 200 euros cost down to 15-30 euros to buy whatever Bluetooth ELM327-compatible tool that the (in Finland) author of xiaotec "850 OBD-II" Android app recommends. "850 OBD-II" app can be downloaded from Google Play for 1-2 euros.
https://play.google.com/store/apps/deta ... c.fi.obdii
https://xiaotec.fi/?lang=en&a=10
viewtopic.php?f=40&t=83145
https://jonesrh.info/volvo850/elm327_re ... ndroid_app
There are many cheap (supposed) ELM327 Bluetooth tools that will *not* work with "850 OBD-II" app, so I suggest getting a specific recommendation from the author (MVS's xanthefin) -- ideally with a link provided where you can immediately go order one. Else buy a ScanTool.net OBDLink LX BT, OBDLink MX BT, or, best yet, OBDLink MX+ (when the price is lower during sales around major US holidays). A BAFX Bluetooth tool also works acceptably well with "850 OBD-II" (though I personally would not buy another BAFX, since it generated too much garbage for my liking).
esl_97_850_T5
esl_97_850_T5
1998 Volvo S70 GLT - 205.5K miles - S70 & M44 testbed in 2016-2019; traded 2019-07-15 (for spare time)
1997 Volvo 854 T5 - 147K miles - 850 testbed in 2012-2017; junked 2017-09
eightfifty2x0
- Year and Model: 1996 850
- Has thanked: 10 times
- Been thanked: 3 times
Hey, thanks a lot for the reply, but i didnt find any link to some OBD2 plug on these links you likedesl_97_850_T5 wrote: ↑16 Jul 2020, 08:15 eightfifty2x0,
esl_97_850_T5
esl_97_850_T5
I suggest you PM xanthefin and ask him for a recommended tool. Tell him you're from Germany, so he knows you are ordering from Europe.
The spec sheet on the 806 says it does support EPB. Thats a pretty high end scanner, I would guess it does.
- hal9000f
- Year and Model: 2013 V70 - 1997 855
- Has thanked: 2 times
FYI.
The following two 10-15 USD bluetooth scanners work with my 855 TDI and the mentioned App:
The orange one is better quality.
Do not buy a dirt cheap scanner. It must have a minimum hardware (NOT software) version v1.4b, otherwise it will not work with the App.
- OBDII-ELM327-01.jpg (13.1 KiB) Viewed 506 times
- OBDII-ELM327-02.png (56.24 KiB) Viewed 506 times
- OBDII-ELM327-03.jpg (23.86 KiB) Viewed 506 times
- OBDII-ELM327-04.jpg (9.18 KiB) Viewed 506 times
- OBD2-Scanner-Connection.jpg (51.33 KiB) Viewed 506 times
[1981 ... 244gld6 D24] - 1992. > 2004.
[1997 ... 855tdi D5252T] - 2004. > today.
[2013 ... V70d3 D5204T7] - 2022. > today.
- 1579 Views
Last post by Volvo Tank
- 10 Replies
- 2713 Views
Last post by hu5ker555
