2008 S60 2.5T 163k
Looking for a cheap one that actually works. I have an Autel OBD2 (MS300), but it just generates a "linking error".
OBDII scanner recommendations?
MarcM
- Year and Model: 2005 S60 2.5T AWD
- Has thanked: 1 time
- Been thanked: 3 times
MD802 if you don't want to carry a laptop around. Does any and every car if you have a fleet.
2005 S60 2.5T AWD
IPD mods:
IPD HD PVC intercooler coupler/upper, HD Subframe poly inserts
ProPartsSweden HD top mount square mount, PPS lower torque rod & control arms.
IPD mods:
- shiloh51933
- Has thanked: 28 times
- Been thanked: 17 times
I recently purchased an Innova 3106e to replace my old on board scanner. It can read generic, factory, abs, srs, ect..
It has real time live data, can erase ABS/SRS/CEL/Service required light. Has USB plug for interface with network for data update.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
Has it been used with any 96-98 volvo's? If so, which model & what features of the tool was used not used? Was looking at the 3170shiloh51933 wrote:I recently purchased an Innova 3106e to replace my old on board scanner. It can read generic, factory, abs, srs, ect..
ugh smh 850 Turbo fridge
- shiloh51933
Used on my 2000 V70XC/se, I had a 98 V70XC which was almost identical except the 2000 has an electronic throttle body with coil packs instead of mechanical TB with dizzy. You can reset ABS light, the service light, reset SRS light, you can check for factory specific data/dtc/I/m monitors/real time live feed, can test battery/alternator/charging system. The list goes on, it's perfect for Volvo owners, it has Volvo specific data already uploaded from the store and you can sync with your PC/laptop for updates. Google it.beigg wrote:Has it been used with any 96-98 volvo's? If so, which model & what features of the tool was used not used? Was looking at the 3170shiloh51933 wrote:I recently purchased an Innova 3106e to replace my old on board scanner. It can read generic, factory, abs, srs, ect..
JRL
- Year and Model: Several
- Been thanked: 16 times
Really any one that works on 2005s and newer should be fine
MAKE SURE THAT YOURS WORKS WITH THAT YEAR AND NEWER.
The system changed with 2005s and the older models and some cheaper models won't work
- 1715 Views
Last post by Volvo Tank
- 2484 Views
Last post by jonesg
- 6366 Views
- 8636 Views
- 1766 Views
Last post by TBrown00
