RooBah
Year and Model: 1995 855T DDriver
Has thanked: 15 times
Post by RooBah »
Brake pedal is slowly going to the floor on the 855T with 320k miles and I only seem to have rear brakes atm.
No leaks so I am installing a master cylinder out of a 855 manual wagon.
The MC reservoir on the turbo has a spring and ball loose inside of it. I searched high and low and cannot find any reference to what it is for (or anything about them for that matter) so I am using the reservoir off the 855 manual donor.
They are the exact same Volvo 3546956 PN (it just has the clutch feed nipple opened up). I closed up the clutch feed nipple but can see no ball or spring inside of it at all. I am about to bleed the MC and proceed with the swap.
https://photos.app.goo.gl/vCo5oyBtimpKsmrVA
87 740 Turbo Wagon w/manual
89 780 Bertone Turbo
95 850 Wagon n/a 5 speed
95 850 Turbo Wagon Auto (The heater hose mod for the PVC is still working perfectly after 35k miles)
*All four previously listed vehicles:https://dl.dropboxusercontent.com/s/a0a ... .44.41.jpg
96 850 Sedan GLThttps://dl.dropboxusercontent.com/s/ct7 ... sitdip.jpg
Has thanked: 1505 times
Been thanked: 3818 times
ZionXIX wrote: 19 Jul 2020, 07:17 When reassembling the drier and AC line should I use teflon tape on the threads or a little antisieze?
The threads don’t seal, the just tension the oring , which seals. Some no- seize will help next time.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Went to drive it to the junkyard today and it started misfiring like crazy. Took the E39 instead.
Now that I look at it again, the ETS light and CEL just popped on. Wonderful... gonna check that out when I feel like walking outside again. Heat index today is over 100 and humid as hell!
2000c70hpt
Year and Model: 2000 C70
Been thanked: 8 times
Post by 2000c70hpt »
Changed the cabin air filter on “Wrinkles” (xc90) cleaned all the trash out of the air box before installing the new filter. New set of Denso spark plugs, and changed the brake fluid for the front brakes. Will do rear next week. Runs so much better and stops better now.
2000 C70 hpt with 140k
2008 xc90 t6 non turbo with 170k
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
I replaced the differential fluid in my BMW. Almost two liters came out but 1.5 was enough to fill it up.
BMW 540i 2002
S70 Base 2000
Slammed an exhaust cam seal replacement on Evita the S70 while deep cleaning the rug, done before 0900.
Took rest of day off.
2000c70hpt
I’m getting ready to do the cam seals on Charlie. My c70.
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 336 times
Post by Chuck W »
Recovered a set of door cards in the wife's 855 to match the headliner.
ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Post by ZionXIX »
Side by side comparison of the old and new AC compressors. Design changes include removal of the front lower driver side mount and deletion of a plug that seems to go nowhere.
2000c70hpt wrote: 19 Jul 2020, 16:58 I’m getting ready to do the cam seals on Charlie. My c70.
Read up on VVT which you will have in the exhaust cam. You need the cam lock tool.
Hopefully, you won’t have to retime it 11 times like me before the Stupid was purged.
