Purchase Advice
ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Purchase Advice
Post by ZionXIX »
I'm looking into buying a nice 2004 xc90 5cyl turbo FWD I saw locally. It's even the color I prefer. Up until this point I have only owned P80 models. What did I need to ask or inspect specifically in this model?
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I would only buy if the seller had it for long time and has a pile of repair bills to show. 2004 starts being old by now. Test the PCV - just slide a piece of saran wrap over the oil filler at idle, should suck it in with force. May also turn the wheels and look at the control arm bushing behind the wheel. See if it looks fine, otherwise it may meant the owner didn't spend much on repairs. The AWD also doesn't last unless it was already repaired. I'd say, besides being a car properly repaired, your biggest fear would be a weird intermittent electrical issue and the gearbox shifting poorly when hot.
2000c70hpt
Year and Model: 2000 C70
Been thanked: 8 times
Post by 2000c70hpt »
Also ask when the timing belt was last changed
2000 C70 hpt with 140k
2008 xc90 t6 non turbo with 170k
wanderdüne
Year and Model: 2004, 2006 XC90 2.5T
Has thanked: 6 times
Been thanked: 45 times
Post by wanderdüne »
Not a lot of difference mechanically to the P80, the front suspension as mentioned above is a wear item for sure. Look for water intrusion/ corrosion ahead of the door jambs from plugged sunroof drains. Can affect CEM on driver side behind dash and yaw control under passenger seat.
ZionXIX
Post by ZionXIX »
Good info, thanks!
Has thanked: 1511 times
Been thanked: 3827 times
Water intrusion, in TX?
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
abscate wrote: 26 Jul 2020, 05:17 Water intrusion, in TX?
Submersion? :lol:.
2011 Volvo XC90 V8 AWD
Mileage 14,502, Damage BACK UP CAMERA; LOW WATER/FLOOD, REPAIRS AVAILABLE
https://www.ecoastauto.com/inventory/de ... 3/M376KJCK
2011 XC90 V8.png (470.91 KiB) Viewed 1124 times
2011 XC90 V8_.png (542.17 KiB) Viewed 1124 times
ZionXIX
Post by ZionXIX »
So I finally went to see the vehicle in person. The body is great condition. Only 1 major dent that I could find. Headlight have no fade at all. It's missing the passenger side marker light cover. Seats are in desperate need of leather treatment but no major tips or tears. Someone replaced the OEM radio for a cheap aftermarket. Little stuff like missing fan speed knob, 1 broken vent, 2 missing button covers on the driver seat controls, drink holder door is broken. Everything I tried worked, windows and sunroof etc.
Drive wise the passenger strut is extremely clunky and you can visibly see the strut tower pushing through. I didn't see any dents under the hood but it definently needs new spring seats and or strut mounts. Somehow every single plug bolt head is coated in a light layer of rust. My p80 lugbolts are original and they look new. Not sure why the rust is formed on there.
Engine is pretty clean but unsurprisingly lots of smoke coming from dipstick tube. I didnt have a glove to test pcv. Right now it's at my trusted volvo mechanic for inspection. What do you guys think so far?
ZionXIX
Post by ZionXIX »
Indie volvo mechanic just called with his evaluation. Short version:
29 codes stored in 9 different computers, many related to battery and fuel system.
Both struts mounts are shot.
Transmission fluid dark
Rear brake rotors below minimum levels
Ripped driver side drive axle
Serpentine belt heavily cracked
Excess crankcase pressure failed glove test
He quoted me 3000 to 4000 for parts, labor and tax.
Thats with struts, mounts and spring seat replacement.
ZionXIX
Post by ZionXIX »
Update: I offered them $2000, they countered with $3500 including tax and title. They wouldn't come down any further. I passed on it.
