ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Post by ZionXIX »
bmdubya1198 wrote: 22 Jul 2020, 11:49 Ugh those quick disconnects SUCK. Such a pain to release. I bet that orifice tube is nasty, mine was caked up with so much garbage. I guarantee someone used stop leak to try to fix the evaporator leak, but of course it won't work since it couldn't get past the orifice tube.
Mine was not quite that bad.
ZionXIX
Post by ZionXIX »
I purchased a bunch of o rings for these ac lines but I dont know which goes where. I have green and yellow that are same size but the green is little thicker. In this picture which looks more correct?
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
I do not have a specific answer, but a generic o ring answer. O rings do not actually compress. They change from round to oval shape to seal. There is also a range of dimensions that are allowed when designing an o ring sealing design. Lacking any other answer, I suggest you use the green (larger diameter) o ring IF you are able to push it on to assemble the joint.
Has thanked: 1505 times
Been thanked: 3818 times
You might find some guidance in a real forum that has a thread like
“comprehensive guide to o-ring sizes”
(i bumped it,,,its got a link to JimBee’s excellent tutorial. Too)
I’ve got a 1998 pulled apart and can make measurements on Friday
HNBR O-rings only, please
Ocelot
Year and Model: 1998, S70
Has thanked: 61 times
Been thanked: 17 times
Post by Ocelot »
Can someone explain to me what does this part do in the AC-system? Just curious! :)
'Hij die zonder zonde is, werpe de eerste steen. Ik buk wel'. Simon Carmiggelt
Recent car
'98 Volvo S70 2.5 10V Europa edition (Freya)
'83 Volvo 340 DLS 2.0 redblock (Loki)
Previous owned Volvo's
'96 Volvo 440 Si 1.8
'87 Volvo 340 GL 1.7
'85 Volvo 340 DL 1.4
ZionXIX
Post by ZionXIX »
Ocelot wrote: 23 Jul 2020, 05:20
The orfice acts as a pressure regulator and filter for the system. Its placed in a very inconvenient place. It could easily have been placed closer to the front of the engine bay for easier access.
CIK7
Year and Model: 95 854T & V70trailer
Has thanked: 328 times
Been thanked: 87 times
Post by CIK7 »
ZionXIX wrote: 22 Jul 2020, 13:32 I purchased a bunch of o rings for these ac lines but I dont know which goes where. I have green and yellow that are same size but the green is little thicker. In this picture which looks more correct?
green are called ac o-rings and designed for ac components. they are more heavy duty and it looks like that would work better than yellow one.
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
CIK7
Post by CIK7 »
wow dude, gross! where is the orifice at? im replacing ac compressor, alternator, ps pump, evaperator, and ac lones for peace of mind for my fresh rebuild.
ZionXIX
Post by ZionXIX »
CIK7 wrote: 23 Jul 2020, 12:15
There are 2 lines running underneath the coolant reservoir to the firewall. The smaller line is actually 2 lines bolted together. The orifice is in that smaller line. You have to remove the line completely before opening. I did it the hard way. I recommend unbolting the pieces behind the headlight before disconnecting at the firewall. It will give you more flexibility. Pay attention to the direction of the orifice when replacing.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Yeah, it's in the AC line along the passenger fender. There are some writeups on here showing the exact location.
